Turbo and supercharger applications...
AEM FIC Plain and Simple
Old 03-24-2010, 10:00 PM
  #41
well crush ur basemap/full tune is dead on for my setup. as soon as i loaded it the car responded so much better. it was a little lean around 16. but all i did was make small fuel adjustments here n there and i could basically get whatever afr i wanted for whatever load i was at.
thanks again for that map!!
gwopsta is offline
Old 03-24-2010, 11:07 PM
  #42
crush02342002's Avatar
your welcome...Im building a map right now for 850cc injectors...just doing closed loop for now till turbo is in.
crush02342002 is offline
Old 03-25-2010, 01:12 AM
  #43
cool, let me know how it turns out...i will be doing a complete build soon
but i wanna see how much i can squeeze out of the stock motor and on the aem fic,
stock except headstuds, i know u wont get very far if these arent installed
gwopsta is offline
Old 03-25-2010, 01:21 AM
  #44
the point of the 850cc injectors for me was to keep idc low while providing enough fuel for 300-350hp depending on how froggy i feel. also i wont really need to upgrade injectors if i go further with things. I could have gone with 750's but hey i was going for the overkill.
Old 12-08-2011, 06:12 AM
  #45
Need a base map asap... please help [email protected]... tune right now keeps throwing misfire codes..
mrperformance is offline
Old 12-08-2011, 08:11 AM
  #46
borderguy881's Avatar
first check that you have your plugs gaped to 28 and also make sure u have no boost leaks
borderguy881 is offline
  #47
whats your setup also i have a few maps
Old 09-27-2012, 08:44 PM
  #48
I am in need of a basemap, Im using AEM fic, currently running 57 trim turbo.
SportyPT03 is offline
Old 08-03-2013, 02:34 PM
  #49
These forums seem dead.
Crush, I would love to contact you...but you don't even go on here much anymore.
somejace is offline
Old 03-31-2014, 01:48 AM
  #50
hey could you send this aem fic software to me? I tried messaging you but it wouldnt let me Thank you
zyzz is offline
Old 04-28-2014, 12:09 AM
  #51
Default Hey could you send me a base map/ map for a t3/t4 ebay turbo tc with 550's?
Hey could you send me a base map/ map for a t3/t4 ebay turbo tc with 550's and 255 fuel pump? Awesome post on the blow through set up btw. That's what I'm going to be running.
BoostedTC1 is offline
Old 07-31-2017, 03:44 PM
  #52
Default Needing base map please!
I need a base map asap! I tried but it screwed me in the end.
Silversquad is offline
Old 07-31-2017, 05:53 PM
  #53
I can help but would need information on your setup in order to make a map.
xile6 is offline
Old 08-01-2017, 04:01 AM
  #54
Default Base map
i have a custom turbo kit put together with a ko4 turbo. Internally wastegated and I'm planning to run 15psi but currently I had it running 10 just nothing seemed to work after the fact and I'm running 1000cc injectors but am planning to run e85. Currently trying to untilize as much as I can from stock injectors as well I believe there 310cc stock so at least have it get me somewhere and maybe max them out to see what they can do. But the 1000's are my next issue lol
Old 08-01-2017, 01:56 PM
  #55
That turbo is way to small.
The stock injector are 370cc they flow around 330 in the low idle area.
E85 uses alot of fuel abd i havent work with it before, so i cant make a map for that.
As far as stock injectors you wont get much power before leaning out.
Around 200hp max id say.
And 1000c are pretty big and they will run the car rich.
Normally with the fic you dont wanna go above half the stock injector size. So that would be able 700cc.
What problem are you having with your map and setup?
xile6 is offline
Old 08-01-2017, 09:21 PM
  #56
Um well I had the car running pretty good at idle and light throttle but past that it leaned out like crazy and didn't wanna drive, then I fixed the wot lean sitiuatuon but screwed the idle and low rpm, so I don't exactly know what to do. And I'm planning on just selling those injectors and getting maybe 550 or 750. But the reason I wanted to see the car on e85 is just cuz it's cheap and the power you can make with it
  #57
I just need want to drive it without too many problems lol
Old 08-02-2017, 08:21 PM
  #58
e85 isnt cheap. Everyone thinks it is but you have to convert what you have on your car now. So you have to factor that cost in. Plus you tend to use more of it. So even you get it for $2 a gal. while normal gas is $3.
your end up paying the same price since your need more e85 then you do 93 octane.
Next
I would say run 93 octane and get the 550 or 750 injectors and tune on that.
If you can make a dropbox link or pm me your tune i can have a look at it.
For the idle area and pretty much everything below 13psia the fuel map should be blank.
Maf map in percent and 0 out.
o2 map in voltage and around 1volt in all cells above 14psia
xile6 is offline
SloTC1
08-16-2018 02:45 PM
vi3tb0i09
09-23-2015 08:32 PM
prescottn
09-13-2015 09:04 PM
Quick Reply: AEM FIC Plain and Simple
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
