View Poll Results: Are you having success with the FIC?
Voters: 18. You may not vote on this poll
AEM FIC success - Paul and Todd please chime in too
#41
Just figured I should post this up in here:
Originally Posted by Tony from UMS
The fix ended up being a couple of 2.2k ohm resistors wired across the cam and crank in wires, I take no credit on it I got the tip from Henry at AEM
#42
Year of vehicle: 2005
Tranny: manual
Injector size: 650cc
MAF piping size: 3"
Recirc BOV: NO...HKS
Upgraded Fuel pump: No
UEGO: Yes...AEM
FIC Version: 3.01...now 3.04
Tune: profesional with minor tweaking
I was one of the fist with the F/IC. My (honda) tuner had a real hard time with it, but got it running. Since then, I got many maps from many others and tried them out...software is REALLY easy to work with.
I then started self tuing some of the base maps I got and had decent results at low boost.
Recently, I went tu UMS tuning in AZ who did many test, spoke with AEM and discovered some issue with the unit and our cars. After wireing up some resisters, and replaceing my bad 02 sensor, the unit started behaving properly...now all is well and I'm making 296whp at 9psi, and that's on a safe, rich tune.
Overall, I am very satisfied and feel that the F/IC is the best and easiest to modify piggyback out.
Tranny: manual
MAF piping size: 3"
UEGO: Yes...AEM
#45
Originally Posted by B_Real45
Someone needs to make a quick schematic or diagram showing the resistor mod - and make it a sticky.
#48
I would say either call up Henry at AEM or Tony at UMS...if I get a chance, I'll look at my box and see if I can see anything different, but I'm not good with electrical stuff...maybe I'll have aen look at it instead...
#51
Originally Posted by tC_2NeR
so do all FIC's need to have the resistors wired in?
i certainely hope not cause i really dont want to be doing anything extra after a long azz turbo install
#52
#53
^ This is correct
2.2k ohm resistor between the Cam1 MAGI+ and Cam1 MAGI-
Read more about my adventure figuring this out: https://www.scionlife.com/forums/vie...23561&start=40
#55
according to this:
http://forum.aempower.com/forum/inde....0;attach=3721
they are pins 9 and 10 on the 24 pin connectors...at least for the 05-06 tc.
#60
Year of vehicle: 2006
Tranny: manual
MAF piping size: 2.5"
UEGO: Yup
FIC Version: 3.01
Tune: profesional
I was Sean Church's first FI/C and i am running with absolutely nooo problems. no stall, sputters, nothing. Didnt have to add anything to it either. :/
Tranny: manual
UEGO: Yup
FIC Version: 3.01
Tune: profesional
