Anyone running AEM Tru-boost?
Old May 5, 2008 | 02:01 PM
enjoithis's Avatar
Default Anyone running AEM Tru-boost?
I just got my turbo installed with the AEM Tru-boost... and i cant quite figure it out.
Can anyone give me a run down on how this thing works?
I did a search and i have found that if you set it at "8psi" it may allow spikes up to 10-12psi?
Thanks.
Old May 5, 2008 | 04:17 PM
jjos1's Avatar
Default Re: Anyone running AEM Tru-boost?
Thanks.
Make sure you break in the turbo first before you start boosting.
Old May 5, 2008 | 04:44 PM
Mr_Meaty's Avatar
there is no setting for psi on the tru boost...it is set up by duty cycle. mines not actually on right now, but you could ask java or ace.
also, check out the gauges section on the forums at aempower.com
Old May 5, 2008 | 04:48 PM
Ace83's Avatar
Ronin Scion
yup, pretty much all is explained in the manual.. and check out aem forum at aempower.. you have to adjust your wastegate crack pressure to avoid boost spikes.
Old May 6, 2008 | 07:33 PM
enjoithis's Avatar
whats duty cycle?
sry noob
Old May 6, 2008 | 07:51 PM
Ace83's Avatar
Ronin Scion
duty cycle is the duration for a work to be completed before it resets.. like what the word itself describes, but not sure too which duty cycle is this truboost talking about.. but yeah the higher % you set the truboost the higher the boost setting
Old May 6, 2008 | 07:57 PM
enjoithis's Avatar
ok so from what i understand you have to test it to see what duty cycle you have to set it at to reach your amount of boost. So after i get tuned ill have to play with it to see what duty cycle it should be at to maintain 8psi
Old May 6, 2008 | 08:00 PM
Ace83's Avatar
Ronin Scion
yes and your wastegate crack pressure too.. but no, have it set first before you tune.
Old May 6, 2008 | 08:06 PM
enjoithis's Avatar
is it safe to be boosting without a tune? (of course after break-in, ive got 200 miles on it so far)
Old May 6, 2008 | 08:29 PM
Ace83's Avatar
Ronin Scion
you can have it set by your tuner.. but you have to hit boost anyways after install so you would know some if there's any install issues like vacuum leaks or something loose.. but it should be done with precaution
Old May 6, 2008 | 08:33 PM
enjoithis's Avatar
yea, im going to give it 300 more miles and next sat im going to RIPP mods for a tune in NY. Im sure theyll set it up for me. I just want to have a better understanding for my own knowledge
Old May 6, 2008 | 08:53 PM
java09's Avatar
so what did you boost your car with?? 08 boost FTW!!!
Old May 6, 2008 | 08:59 PM
enjoithis's Avatar
Dezod s1 - FTW is right!
Old May 6, 2008 | 09:27 PM
coryjames's Avatar
ummmmmmm dezod ummmmmmmmm thats second place in my book
TT ftmfw fools hahahahahaha
Old May 7, 2008 | 02:13 PM
enjoithis's Avatar
Old May 7, 2008 | 05:20 PM
java09's Avatar
i too am boosted by Turbomother____ingToyotas and they are for the win!!!! haha but at the same time i got a lot of my performance parts i.e. exhaust, suspension, tuning and what not from dezod!
Old May 7, 2008 | 09:17 PM
jjos1's Avatar
Custom kit ftw
Old May 7, 2008 | 10:20 PM
coryjames's Avatar
i would buy from dezod where there shiping not out of control and they had more parts for my car
Old May 7, 2008 | 10:37 PM
rhythmnsmoke's Avatar
Music City Scions
You mean to tell me the filters didn't catch that!
Old May 7, 2008 | 10:39 PM
Music City Scions
Originally Posted by jjos1
Custom kit ftw
HELL YEAH!! To All others....
