Base Map for AEM F/IC
I was looking for a base map for an AEM F/IC. We are finishing up my turbo conversion, and I would like to be able to atleast drive my car on the trailer so I can take it to the tuners, but because they are 700cc injectors, its having difficulty starting.
Any help with that would be greatly appreciated. Its a 2006 tC, t3/t4 57 trim turbo, 700cc injectors, looking to run 8psi.
If you could PM me.
Thanks guys!
If you could PM me.
Thanks guys!
Last edited by MR_LUV; 02-07-2019 at 07:02 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
I also need one if you can PM me. I'd appreciate....sorry for thread jacking man...
___________
___________
I used this to get mine on the trailer. Scroll to the bottom of the page to Base Maps. I have a Garrett GT2252 on a 1gen xB w/ 550cc injectors, but worked well enough. If you need to, go into the fuel map w/ the AEM software and resize the map injectors from 550cc to 700cc, it's pretty easy to do with the software. AEM's forum has a ton of info.
http://www.dezod.com/tech_notes.cfm
__________
Last edited by MR_LUV; 02-07-2019 at 06:57 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
Ok, apparently linking the page the AEM tC map is on is too much, so here's the direct link:
http://www.dezod.com/files/AEMBASECALtC0506.fi6
No pay to play, hiding files, etc. but also USE AT YOUR OWN RISK! I do not know what size injectors this map is tuned for, and highly recommend using a scanguage to check fuel trims / wideband O2 for AF/R. Even then, only use it to get your car to a trailer or local dyno and get a proper tune.
i just sent the 3 guys with emails looking for base maps on aem fic two maps via email one with 550 injectors and the other with 630 injectors, they may need minor tweaking or sucomething depending on the spoiling of your turbo, hopefully these help guys.
I need a base map for 550cc injectors, Please PM me and help me out.
___________
___________
Last edited by MR_LUV; 02-07-2019 at 06:59 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
Just installed a kit 550 injectors. Someone hook me up with a map please Churches automotive is about 30 miles away.
Please PM me.
Thanks.
_________
Please PM me.
Thanks.
_________
I have tons of basemaps available. Please PM me. please include your SL username.
__________
__________
Last edited by MR_LUV; 02-07-2019 at 06:49 AM. Reason: email and/or Personal Info prohibited Per Forum Rules
