Base Map for AEM F/IC
all u guys lookin for base maps should check ur atmospheric pressure thru the fic and try to get a base map from someone closer to ur area for better results. altho no 2 cars are the same and ull def need to be tuned, itll get u a better, stronger starting point as climate, and atmospheric pressure play a key factor in ur tunes.
for example, i got a base map from crush, hes in tx, im in ny, altho our atmospheric pressures werent too far off, i was still getting codes. and also for those that are getting maps for 550 injectors, u can resize them thru the fic but it wont recalculate based off the original map. theres a formula that u can use to adjust it.
ex: 550cc / ur current injector size - 1
and thatll give u ur percentage to increase by.
hey guys i could really use a base map for 440cc injectors if u could help me out.
Please PM me. Thanks.
__________
__________
Last edited by MR_LUV; 02-07-2019 at 06:51 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
I have tons of basemaps available. PM me. please include your SL username.
Last edited by MR_LUV; 02-07-2019 at 06:52 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
540cc injectors
I used this to get mine on the trailer. Scroll to the bottom of the page to Base Maps. I have a Garrett GT2252 on a 1gen xB w/ 550cc injectors, but worked well enough. If you need to, go into the fuel map w/ the AEM software and resize the map injectors from 550cc to 700cc, it's pretty easy to do with the software. AEM's forum has a ton of info.
http://www.dezod.com/tech_notes.cfm
#metoo
Hey, I was hoping that someone would still have a base map available.
If you do you can please PM me. I have a 08 tC running a Dezod kit.
___________
___________
Last edited by MR_LUV; 02-07-2019 at 06:55 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
