Base Map for AEM F/IC
Old Oct 4, 2011 | 03:06 PM
PeArLwHiTe07tC's Avatar
all u guys lookin for base maps should check ur atmospheric pressure thru the fic and try to get a base map from someone closer to ur area for better results. altho no 2 cars are the same and ull def need to be tuned, itll get u a better, stronger starting point as climate, and atmospheric pressure play a key factor in ur tunes.
for example, i got a base map from crush, hes in tx, im in ny, altho our atmospheric pressures werent too far off, i was still getting codes. and also for those that are getting maps for 550 injectors, u can resize them thru the fic but it wont recalculate based off the original map. theres a formula that u can use to adjust it.
ex: 550cc / ur current injector size - 1
and thatll give u ur percentage to increase by.
Old Oct 11, 2011 | 11:16 PM
spankyy's Avatar
hey guys i could really use a base map for 440cc injectors if u could help me out.
Please PM me. Thanks.
__________
Last edited by MR_LUV; Feb 7, 2019 at 06:51 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
Old Oct 19, 2011 | 01:15 AM
DeAnzaJig's Avatar
I have tons of basemaps available. PM me. please include your SL username.
Last edited by MR_LUV; Feb 7, 2019 at 06:52 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
Old Aug 5, 2012 | 07:06 PM
RS1number1536's Avatar
Originally Posted by ProTuner06
Problem with Dezod's is you have to pay for it. I have one for a Dezod kit that is a street tune from Mike and Crush. I'll send it to the both of you.
could you pm me that too? please?
Old Aug 6, 2012 | 01:49 PM
paul_dezod's Avatar
Scionetics
KAD
Allow me to clarify, if you are the original purchaser of the kit, the base cal is free of charge. All other people, parties etc are charged a fee for base calibrations.
Old Apr 29, 2014 | 01:02 AM
fervega2's Avatar
Default 540cc injectors
Originally Posted by DeAnzaJig
I have tons of basemaps available. Txt or call me at 779-279-4962. please include your SL username.
Fervega2 hi I really need a 540 - 550 cc base tune my car won't start with the dezod base tune injector I barely finish upgrading my engine and injectors size
Old Apr 29, 2014 | 01:18 AM
BoostedTC1's Avatar
I need a good map for 550 injectors walboro 255 and ebay t3/t4 57 trim at 9psi.
Someone hook it up.
Old Aug 1, 2016 | 01:47 PM
413angel's Avatar
Originally Posted by vettereddie
I used this to get mine on the trailer. Scroll to the bottom of the page to Base Maps. I have a Garrett GT2252 on a 1gen xB w/ 550cc injectors, but worked well enough. If you need to, go into the fuel map w/ the AEM software and resize the map injectors from 550cc to 700cc, it's pretty easy to do with the software. AEM's forum has a ton of info.
http://www.dezod.com/tech_notes.cfm
Hey man sorry im years late but i have an aem fic and the base map wont allow me to start my car i plan on buying 550cc injectors to go along with my walbro 255lph fuel pump do you think you can send a basemap to help a brotha out? And i also am using the stock fuel pressure regulator.
Old Feb 7, 2019 | 02:54 AM
deficientc's Avatar
Default #metoo
Hey, I was hoping that someone would still have a base map available.
If you do you can please PM me. I have a 08 tC running a Dezod kit.
___________
Last edited by MR_LUV; Feb 7, 2019 at 06:55 AM. Reason: email and/or Personal Info prohibited Per Forum Rules except Sponsors
Old Oct 1, 2024 | 11:17 PM
byt's Avatar
byt
is that tune AEM EMS-4?
Old Oct 1, 2024 | 11:28 PM
byt's Avatar
byt
hello would you kindly or can you email this base tune to me. i have been desperately trying to get my car started for the last month and no luck i already damaged the starter from trying so much to get it to crank over. its a 06 TC with the Boomslang harness with AEM EMS-4. it would be greatly appreciated
email: orlando@mobilityelevator.com
Gripking
20
Oct 10, 2012 01:58 AM
06scionbhs
Aug 9, 2009 06:44 AM
Liek
9
Mar 26, 2009 03:51 AM
eminence
Feb 22, 2009 03:56 PM
toyota_scion_tc
Jan 16, 2009 10:34 AM
