Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion tC 1G Forced Induction (https://www.scionlife.com/forums/scion-tc-1g-forced-induction-1645/)
-   -   Boost Controller information (https://www.scionlife.com/forums/scion-tc-1g-forced-induction-1645/boost-controller-information-188836/)
rougenite Jun 21, 2010 01:47 AM
So I know I need one of these...soonish :)
I have tried searching around the internet for reviews on the different boost controllers, but haven't really found any solid pros/cons for any of them.
Please, if you use one of these post on here what it is and what the pros/cons are.
rangerryda Jun 21, 2010 02:51 AM
Manual boost controller is stupid simple to hook up. Turbosmart makes a decent one at a decent price. They're all about the same but it's important to get one you can trust.
jsmillie07 Jun 21, 2010 03:02 AM
I use a greddy profec b spec II. It is an expensive boost controller but it has a low and high boost setting. Also it has a warning for over boosting and controls how the wastegate opens.
a-mendoza Jun 21, 2010 03:06 AM
I personally run an electronic Greddy profec B-spec II boost controler.
Pros
1.)Unlike a manual boost controller, the wastegate will see no pressure till its time to activate. This means the wastegate will stay fully closed till i hit my desired boost level wich means faster spool up and less lag.
2.)Has a warning function for overboost and will lower boost till your back to your desired boost level.
3.)Saves two different settings for your high and low boost with just a hit of a button.
4.)Has a digital screen that shows your current boost level. Basically it eliminates the need for a boost gauge.
5.)Recalls the highest boost pressure your engine has seen
Cons
Pretty damn expensive
Blue_TC_Man Jun 21, 2010 03:11 AM
the profec B is awesome I have a few friends that run them. I personally dont run a BC and have no problems, but if I did id get the profec
RusWolf Jun 21, 2010 05:24 AM
I run greddy profec as well. You have to look for a deal, i bought mine for $250 shipped brand new thanks to ebay.
rougenite Jun 21, 2010 04:44 PM
$250 is not bad considering what I have already dropped. I still have a little while to figure this one out. I appreciate the posts so far!
rangerryda Jun 22, 2010 05:56 AM
If it deals with controlling boost at safe levels or providing it in a safe way, pay the price for premium and reliable products (turbos, WG's, and MBC's).
rougenite Jun 22, 2010 10:10 AM
I agree with you totally! This is yet another fail-safe. It is something i can skip for now.
gingles Jun 22, 2010 07:46 PM
the profec b is the way to go....or the blitz dual solenoid one....but the blitz is hella expensive.
the profec also allows you to control how hard and when boost comes in. you can adjust 2 diff gain settings...in other words...boost come in late and hard and you dont spin off the line.
DezodDon Jun 22, 2010 09:00 PM
I am more of a fan of a great manual boost controller than an electronic one because I like simplicity. Keeps things reliable.
However if you are looking for a good electronic one that doesn't break the bank I like the AEM tru boost gauge.
http://www.dezod.com/pd_aem_truboost.cfm
Boost gauge and controller all in one.
Other than that I prefer a good manual like said before. I like this one as it has proven to be trust worthy.
http://www.dezod.com/pd_hks_variable_boost.cfm
jwallace045 Jun 24, 2010 05:44 AM
yo don, I just met you today while at the shop, Im already wantin to run more boost, I have a manual Turboxs boost controller, this means i can turn up that 4/5psi spring to 8/9 lbs of boost right?!
rangerryda Jun 24, 2010 06:34 AM
^ sure can
Ace83 Jun 24, 2010 01:33 PM
I like the concept/functionality of truboost.. boost gauge and controller, eliminates extra wiring and setups.. but as a boost controller itself, its mediocre at best in my opinion.. it doesn't keep boost dead consistent but when setup well can be close.
Ace83 Aug 21, 2010 04:06 PM
so im thinking of changing my boost controller.. and saw this,
http://www.ptuning.com/html/Item-Des...niversal%20Fit
anyone with experience with this?
always been a fan of gauge type EBC so i can mount it on my pod and use it as a boost gauge as well. truboost did a decent job for me but im switching my to innovate wideband so might as well switch my other gauges that matches the blue LEDs of my wideband
Rob_DESCENDANT Aug 21, 2010 06:18 PM
WORLD electronics BD-1 is $199.95 and is honestly the best bang for your BUCK!
Call me if you have any questions. I have them in stock & will offer a SL 20% discount.
http://www.world-motorsports.com/wms...2737e8c3e08693
Rob C.
310.533.8900
XPRTc Aug 21, 2010 08:16 PM
Anybody running the A'PEXi AVC-R II EBC?
http://www.dezod.com/pd_apexi_avcr_ii.cfm
Expensive and maybe excessive, but it looks like it has some pretty trick functions when you figure out how to program it like boost by gear for example.
Rob_DESCENDANT Aug 21, 2010 10:15 PM
Originally Posted by XPRTc (Post 3661330)
A'PEXi AVC-R II EBC
good luck...
tcturbo07 Aug 21, 2010 10:38 PM
runnin aem tru boost works like a charm
XPRTc Aug 21, 2010 11:27 PM
haha Rob for some reason when somebody says that it makes me feel like they know something I don't. So, let's talk about that BD-1 then haha.
© 2026 MH Sub I, LLC dba Internet Brands
