Boosted tC running Descendant racing turbo kit w/ built motor....
Yea my tuner tried call Descendant for the specs and couldnt get a exact answer....so today when i get home im gunna see if theres part number engraved and call precsion turbo and see what i come up with.....what i was told that it was 63 on the cold side and 60 or 61 on the hot.....
Im sad you left me out of the Big Dog catagory..lol
ok so...timing was fine so thats ruled out.....so heres my set up
Descendant Racing V2 turbo kit
.55 trim v-band Precsion Turbo
AEM FIC
38mm Tial wastegate
Forged diverter valve
3 inch Descendant Racing exhaust
RC750cc injectors
Descendant fuel rail
Walbro 255lph fuel pump
Dezod custom fuel return
NRG fuel pressure regulator
NRG oil catch can(not installed yet)
AEM Tru Boost controller
AEM wideband o2
Agengy Power crank pulley
Energy Suspension motor mount inserts
Engine Internals (thanks to Paul @ Dezod)
Wiseco 9.0:1 pistons
K1 Technology rods
Cometic head gasket
Arp head studs and rod bolts
ACL main and rod bearings
REV Dual Wound Valve Spring & Retainer
REV valves
Dezod vacuum block
Transmission
TRD LSD
ACT 6 puck sprung
with ACT's most aggresive pressure plate
TWM base bushings and cable transmission bushings
AEM FIC
38mm Tial wastegate
RC750cc injectors
AEM wideband o2
K1 Technology rods
Cometic head gasket
REV valves
Dezod vacuum block
Transmission
TRD LSD
ACT 6 puck sprung
AEM FIC
38mm Tial wastegate
RC750cc injectors
AEM wideband o2
K1 Technology rods
Cometic head gasket
REV valves
Dezod vacuum block
Transmission
TRD LSD
ACT 6 puck sprung
AEM FIC
38mm Tial wastegate
RC750cc injectors
AEM wideband o2
K1 Technology rods
Cometic head gasket
REV valves
Dezod vacuum block
Transmission
TRD LSD
ACT 6 puck sprung
The biggest power makers on these motors are:
1. Removing the Balance shafts
2. Headwork and Cams
3. Turbo (Bread and Butter) this is where most of your money should be spent. Never hold back on this one. Cut coners somewhere else. Like Valves.
