Buyers Guide: Scion tC Forced Induction
#281
Originally Posted by coryjames
Yeah i hit similar numbers on 8 pounds but im on the e85
Big $$$ saving & runs a lot cooler!
#282
thats low numbers for the boost with the el mani and all
#283
[/quote]
this was on an xB?[/quote]
actually I might be wrong...
After looking at the date this dyno sheet might be from one of the Scion tC test cars back at WORLD-Motorsports East. I will double check & confirm.
#284
Want to learn more about turbo kits in general? Please head here:
ScionLife Official Turbo FAQ Sheet
THIS IS FOR INFORMATION PURPOSE ONLY!!! NO FLAME WARS ARE TO START!! KEEP IT SANE AND KEEP IT ON TOPIC! PLEASE DO NOT REFER SOMONE TO ONE SPECIFIC COMPANY LET A PERSON DECIDE ON THEIR OWN!
Dezod-Stage 1 for a/t avaliable for 2005-up models
www.dezod.com
Components:
Turbonetics Dezod Spec'd T3/T4 Turbo
Stainless Steel Manifold
TiAL 38mm Wastegate
Charge Piping w/ Intake
Dezod Turbo Install Kit (Special to kit to ensure perfect fitment)
Stainless Steel downpipe w/ S-Pipe (extra value)
HKS SSQV Blow Off Valve
550cc injectors w/ clips
Stainless Steel Braided Oil Lines & Oil Pan Fittings
Dezod Large Bar & Plate Front MountIntercooler
T-Bolts & Couplers
*Plug N Play GReddy E-manage w/ a base map
B&M Transmission Cooler
*Plug and play harness includes main, injector and ignition harnesses
Dezod-Stage 1 for m/t avaliable for 2005-up models
www.dezod.com
Components:
TiAL 38mm Wastegate
T-Bolts & Couplers
On Dezod kits each one have an optional lower priced kit with out emanage.
Greddy- m/t avaliable for 2005-2006 models (MAF Adapter for 07-up models)
www.greddy.com
TD05H-18G
Type 31V Intercooler
Aluminum Intercooler Piping
Tubular Turbo Manifold
Cat-Delete Downpipe
Greddy has 2 optional addons for this package one including 4x 440 inj, programed emanage or 4x 440 inj, programed Ultimate
Turbonetics – m/t or a/t 2005-2006(need verification on 2007-up models)
www.turboneticsinc.com
Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E)
Spearco Intercooler System
Powder-Coated Intercooler Piping
Silicone Hose / T-Bolt Clamps
Exhaust Manifold - high carbon cast-steel with ceramic coating
Fuel / Timing Controller (electronic fuel / timing management system)
Fuel Injectors
"Evolution" Wastegate Assembly
"Raptor" By Pass / Blow Off Valve Assembly
Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
Intake System with Air Filter
All necessary Hardware, Hoses, and Fittings
Free Case of Turbonetics TS-1 Synthetic Motor Oil
ZPI - No longer in business but turbo kits turn up on classifieds once and awhile.
Treadstone Scion Tc Turbo kit m/t 2005-2007 models
http://www.treadstoneperformance.com...ct.phtml?p=238
Brand new custom spec T-Series Garrett turbocharger
Turbonetics Evolution Wastegate
Greddy Type RS Blow Off Valve
Super efficient front mount Bar & Plate Intercooler
Performance Spark Plugs
Fuel Upgrade
Racing Cast Iron Exhaust Manifold
Polished aluminum piping with Silicone and T-bolts
aerospace oil drain and feedline.
High flow air filter
Precision machined velocity stack MAF adapter
Get engine management with this kit for better performance and longevity.
Turbo Toyotas (TT)- No longer exists!!!
http://whyindustries.com/store/
"Simple" complete kit
Turbotoyotas entry level turbo kit....SIMPLE and priced right
The most affordable complete "entry level" turbo kit on the market
available for 05-06 and 07-09 TC
T3/38 flanged stainless steel log manifold
Garrett T3/T4B Stage 5 wheel (choice of .63 or .82ar)
Tial 38mm WG
Choice of Greddy or HKS BOV
22 x 8 x 3.5 Intercooler
Aluminum chargepipes with couplers/clamps NEW PIPE ROUTING requires the removal of the factory fans/shroud. black powdercoating is standard
2.5" aluminum intake pipe with maf flange and AEM air filter powdercoated black is standard
2.5" Stainless steel downpipe
stainless steel dump tube(non recirc)
pre-tapped oil pan
FUEL MANAGEMENT
AEM FIC fuel/ignition controller
550cc plug n play injectors
Plug n play adapter for AEM FIC
Oil feed/drain lines
Vacuum block with fittings
2 12" slimline fans
All installation hardware
Included "extras":
Choice of black or polished ceramic coated manifold/ dp and s-pipe/ turbine housing (all 3 will match based on color selection)
AVAILABLE FOR AUTOMATICS
Ver 2.1 Stage 1 Turbo Kit:
300whp + at 8-10psi
Good all around kit for those wanting that little bit more from there daily driver
T3/38 Stainless Steel Equal Length Turbo manifold....Version 2.1
Garrett T3/TO4E Tubocharger 57trim .63ar
3.0" Stainless Steel Downpipe and S-pipe combo with extra 02 bung for wideband sensor
Tial 38mm Wastegate(.5bar spring)
Greddy or HKS BOV
2.5" Aluminum intercooler piping w couplers and t-bolts clamps : powdercoated black
Custom Garrett Intercooler core with fabricated end tanks
2.5" air intake with AEM Dry Flow air filter powdercoated black
Turbotoyotas vacuum manifold with fittings
Steel Braided Oil Feed and Return lines
Hardware and installation instructions
FUEL MANAGEMENT IS NEEDED TO RUN THIS KIT AND CAN BE PUCHASED ALONG WITH THE KIT AT ADDITIONAL COST
P-Tuning-
www.Ptuning.com
Specs on the PTUNING SPEC-SS Turbo Kit (Tuner Kit):
Turbocharger:
Garret T3/04E 57 trim .82 A/R with v-band turbine outlet.
SS Braided oil feed line.
SS Braided oil return line.
Exhaust Components:
Full 304 SS equal length low-mount tubular manifold with a long, narrow angle merge collector (Same as the one on our Ptuning TA tC).
Tial 38mm v-band MVS Wastegate (new Tial design) (8.5 psi spring).
304SS external dump tube.
Full 304SS 3" v-band downpipe. The downpipe is designed to bolt directly to our Ptuning 3" exhaust system (either turbo-back or s-back).
Piping/Intercooler Components:
22"x8"x3.5" bar&plate Intercooler with 2.5" in/out w/cast end tanks.
2.75" 6061 aluminum upper intercooler piping w/beaded ends and blow-thru MAF housing.
2.5" 6061 aluminum upper intercooler piping w/beaded ends.
4" 6061 aluminum cold air intake.
Upper I/c piping will include a pre-welded bung for Water/Meth injection.
Tial 50mm v-band Q-BOV (new Tial design).
304SS T-bolt clamps for all connections.
4/5 ply silicone hose connectors.
I/C piping in either PTUNING Texture Red or PTUNING Texture Black.
AEM Dryflow 6" cone filter/ w/ 4" opening.
2 SPAL radiator fans.
*Intercooler paint options available as well as Engine management/ Injectors.
Descendant-
http://www.descendant-racing.com/
“Bolt-on & Go” 2005-2006 Scion tC Turbocharger Kit. Complete 100% Turn Key Turbocharger Kit that includes:
DESCENDANT Tuner Friendly Turbocharger kit
DESCENDANT S.S. Turbo Manifold
DESCENDANT Aluminum Intercooler Tubing Kit
DESCENDANT Front Mount Intercooler
DESCENDANT OBD2 DownPipe
DESCENDANT Emission Control Brackets & Mounts
DESCENDANT P-N-P Engine Wire Harness
DESCENDANT Custom Fuel Map
BullsEye Power Turbo
AEM F/I C Controller
RC Injector P-N-P 750cc Injectors
“TUNER FRIENDLY” 2005-2006 Scion tC Turbocharger Kit.
Kit that includes:
DESCENDANT o2 housing
ATP Turbo- www.atpturbo.com
Stage 3, 450HP or 500HP (turbo choice dependent), GT3071R or GT3076R, dual ball bearing kit. All hardware with new 38mm wastegate. Features 3" Garrett GT V-Band exhaust housing and Tial 38mm wastegate with V-Band connections.
http://www.atpturbo.com/mm5/merchant...egory_Code=STC
Stage 3, 350HP or 400HP (turbo choice dependent), GT28RS or GT2876R, dual ball bearing kit. All hardware with internally wastegated setup.
_______________________________________________________
Ok now this is info from the first post by PeteyD and updated info I got from websites. All info may not be correct and purchase at your own risk. I may have forgot some turbo kit manufacturers but let me know and I will update accordingly. I tried to get updated info so again please use this as a reference and contact the actual manufacturer for purchasing/turbo kit info.
Good luck and Happy Boosting!!
#285
A TRUE TURN KEY SOLUTION...DESCENDANT Turbo Kits are the best bang for your buck because of WORLD-Racing's experience, WORLD-Motorpsorts customer service & the warranty program...let alone it's made here in the USA
#288
This is a guide for your options. But any of the listed kits will give you anywhere from 230-350whp depending on supporting mods(exhaust, water/meth injection),psi and your tune. Just go to the websites of each turbo kit producer and then search there name on the F/I forum and read up on them. It all depends on what your looking for cause they all produce similar enough power. Also Turbo Toyotas doesnt exist anymore.
#289
If your car is a daily driver and you want the most powerful & realiable turbo kit out there...this is the best bang for your buck hands down
#292
Ok i fixed and updated some things!
www.dezod.com
Components:
TiAL 38mm Wastegate
T-Bolts & Couplers
www.dezod.com
Components:
TiAL 38mm Wastegate
T-Bolts & Couplers
www.greddy.com
TD05H-18G
Cat-Delete Downpipe
Fuel Injectors
Fuel Upgrade
Tial 38mm WG
pre-tapped oil pan
FUEL MANAGEMENT
2 12" slimline fans
Included "extras":
300whp + at 8-10psi
Greddy or HKS BOV
P-Tuning-
www.Ptuning.com
Turbocharger:
Exhaust Components:
Descendant-
Kit that includes:
www.dezod.com
Components:
TiAL 38mm Wastegate
T-Bolts & Couplers
www.dezod.com
Components:
TiAL 38mm Wastegate
T-Bolts & Couplers
www.greddy.com
TD05H-18G
Cat-Delete Downpipe
Fuel Injectors
Fuel Upgrade
Tial 38mm WG
pre-tapped oil pan
FUEL MANAGEMENT
2 12" slimline fans
Included "extras":
300whp + at 8-10psi
Greddy or HKS BOV
P-Tuning-
www.Ptuning.com
Turbocharger:
Exhaust Components:
Descendant-
Kit that includes:
#295
#296
#299
Here is the link to the Sound Performance kit. I didn't see it on the updated list at all for some reason. I saw this on one Scion tC and it was a pretty decent kit. I think I'd still perfer my Dezod kit to this kit though.
http://www.spracingonline.com/store/...Turbo_Kit/3231
#300
Hey there!! im a noob to Scion Life and also have an 06 silver tc. However i am not a noob when it comes to the FI world. There is a kit made by Boost Flow and from what i can tell it is the best value and has the most power out of any other kit on the market for the stock motor. They claim 304whp on 9 psi. The kit is 2995 without fuel management and with fuel management its 3400. There kit is on customcarscentral.com
