Car not starting after Turbo..Help!
Old 04-04-2019, 04:50 PM
theWetSheep's Avatar
Default Car not starting after Turbo..Help!
Hi guys. I recently saw an older thread on here about using the TRD reflash with a small turbo and decided to try it out. Im running a TRD ECU with 440cc fuel injectors IND 42.50MM EXD 60mm Trim 50.17 turbo (it is an eBay kit, I know I know don't buy eBay I've had the lecture before).
I only have the waste gate set to 5psi so I assume this would be a safe setup. However I got everything installed and decided to take it around the block, it rode fine no CEL or other lights, (I did have a very slight oil leak around the oil drain bung that I need to fix) but when I stopped
at a light the car stalled and would no longer start, crank but no start, any ideas?
Would I be better off running the stock ECU and injectors since the turbo is such low boost? I've read the old stage 0 kits ran with with fuel upgrades and that is sort of the kit I'm trying to emulate.
Any help is much appreciated.
_______
theWetSheep is offline
Old 04-09-2019, 01:21 PM
etoomey3's Avatar
I've ran a Scion tC with a turbonetics kit with 440cc injectors, on a stock ECU. I couldn't get anyone locally to tune the Unichip it came with. I ran a stock ECU with the turbo kit for a few months until I got my e-manage ultimate & got it tuned. There are some drive-ability problems with the stock ECU + turbo. The idles suffers, and between shifts suffers, but A/F readings were fine, and the car seemed to run well.
etoomey3 is offline
Old 04-15-2019, 09:14 PM
You ran a stock ECU as in non TRD reflash right?
ScionFred
33
08-05-2011 02:08 AM
Irish B
09-29-2010 08:41 AM
Rydrdg
02-09-2008 04:56 PM
Frozt0
30
10-15-2007 05:49 PM
kikcaffine
07-24-2007 03:08 AM
Quick Reply: Car not starting after Turbo..Help!
