car stalled now rough idle (any advice)
Took the car out friday just to drive it around the block I try to do this every two weeks just to keep everything from sitting. I take off from a stop light car just stalled when I go turn it over it won't start, try again this time with apply gas it started but sounded like a wrx . so I went home pulled the plugs, checked all my vac lines, piping and couplers and everything seems tight. I also put my coil packs and plugs into another tc and it ran fine so now I'm stuck car has less then 1500 miles. I will do a boost leak test some time this week and see if anything shows.
heres what the car sounds like now
http://s217.photobucket.com/albums/c...217_131730.mp4
Vacuum I can't really read cause idle is rough so its all over and my a/f was in the 10s so i didnt want to keep the car running. I also cant give u codes I have a Haltech standalone as far as a comp test I will be going to autozone to rent a gauge out. Also the car has a fully built longblock
May still be salvageable just need a good hone, new piston and rings. Rod too depending on damage.
Cant seem to put together on what happened on somebody with a built motor with less than 1000 on the build. Try to find out what caused it.
Who put it together? What time of fuel did you use? Was it assembled correctly?
All of these plus more are factors that come into play.
me we shall see soon but motor was built by erl manly turbo tuff rods and cp pistons i am starting to thing it was the tune or just bad injector. cause all the rest were fine and that was 5 cranks i got 160 and i let it crank for a while it went past 180 like 8 cranks
