car stalled now rough idle (any advice)
OK I am thinking that a I have bent valves. I go today but some oil in the chamber let it sit then added a little more and still no compression. And to me the spark plugs all look fine. Just thinking out loud
i just think its rich now cause a valve is bent or stuck and its not compressing to make the chamber fire and think if i had a hole in the piston or messed up rings i should be showing and smelling oil out the tail pipe. just my opinion
umm when it happened it sounded like a subi and i had a flashing cel the car then fell on its face, pulled over and tried to rev it a lil bit and then it started smoking like crazy so i killed it. and yea the one cylinder had oil on it.
this is the piston. good luck man hopefully yours isnt as bad as mine. i had less than 4000 miles on my motor and since i had it bored from the last time i had it built i had to either sleeve or get a new block so i went ahead and had it sleeved.
ok this might be the wrong way but i can't seem to find a leak down tester anywhere except online. so instead of ordering one i was going to set my compressor to 60psi screw it in the chamber] that read nothing at TDC and see if i hear or feel anything. i really don't care about the percentage lost just want to know were the problem is. just want to to know if i should send my other head out to ptuning. so i will post results once the rain calm down.
