CEL post turbo install-Now a different code....
Old Jan 9, 2010 | 04:11 PM
ElevationTC's Avatar
seen this before.
Old Jan 9, 2010 | 04:18 PM
3min3m2's Avatar
Elevation do you know of any other way to get rid of it?
Motor is running good right now...besides an AFR of 10 at WOT
Old Jan 9, 2010 | 06:11 PM
crush02342002's Avatar
mike should know, he runs are has run using the ultimate.
Old Jan 10, 2010 | 11:53 AM
skakemokid's Avatar
do you have your jumper settings correct?
Old Jan 10, 2010 | 03:42 PM
3min3m2's Avatar
As far as i know...everything else works fine
**bump for new CEL...I'm thinking its the O2...
Old Jan 11, 2010 | 05:25 AM
whats the code?
Old Jan 11, 2010 | 04:49 PM
3min3m2's Avatar
Thought i posted it. It "was" a P0037. came twice, cleared both, haven't seen it since(two days)
Old Jan 11, 2010 | 10:43 PM
sounds like the secondary o2 sensor may be damaged, connectors corroded, too far out of the exhaust stream, or exhaust leak. its my understanding that the e-ultimate doesnt have anything to do with any of the o2 sensors so i assume nothing should be spliced or taping into the o2 wires. in other words ther shouldnt be any extra wires comeing off of the o2 sensor leads running to the managment if im not mistaken. however i havnt played with the e-ultimate so take what iv said about it for a grain of salt.
Old Jan 11, 2010 | 10:53 PM
weezyfbayba's Avatar
dude dont hit wot till ur tune plz
Old Jan 12, 2010 | 03:54 AM
3min3m2's Avatar
Don't really have a choice...no one here to tune me, but myself...
So I'm working on tuning it myself...with a good bit of research and advice...and its going pretty good...
crush, that is what i was thinking as well...I;m thinking it is the o2 going bad, because i had an issue with it before...that or it is the rich AFR, as it only comes around when i try to tune, when i go into boost and what not...
Old Jan 12, 2010 | 05:47 AM
it will be a learning exp for sure....wish you the best of luck with it
Old Jan 17, 2010 | 11:02 PM
3min3m2's Avatar
bump for new symptoms...seeing if theyre code related...
Old Jan 17, 2010 | 11:09 PM
sooo what are they or are you refering to the o2 code? what have you tried so far?
Old Jan 18, 2010 | 12:23 AM
3min3m2's Avatar
Yeah sorry thought i specified it. Its "causing" the idle to bounce around sometimes i do believe. right now I've tried clearing the code...thats about it...I plan on replacing it soon anyways, I'm thinking the wiring is messed up...
Looking to see if anyone had experience with what all it controls...
Old Jan 18, 2010 | 02:40 AM
blown_xa's Avatar
The emanage is not like the fic, I suggest to just unplug the o2 sensors all together as a starting point (to determine cause of car's symptoms) then reset ECU by disconnecting battery for a minute. I don't run o2 sensors in my car at all other than a wideband af sensor. Unplug the o2 sensors, tune it. Make sure cars runs well with correct afr. Then plug them up, if the tune goes wack the o2 could be bad.
I know you have to take the case off the Ultimate and set the jumper settings correctly for the tC (not the ones on the outside), I see Toan (our tuner) do it all of the time. That could be your issue. Also the maf sensor will max around 5psi so I would suggest pressure sensor for a better tune if you don't have it.
Old Jan 18, 2010 | 02:43 AM
blown_xa's Avatar
I have seen the idle bounce before and it was the primary o2 bad. Unplug it and see if the idle smoothes out. Tune from there
Old Jan 18, 2010 | 08:35 AM
3min3m2's Avatar
Sounds good. What codes should I expect without second O2 installed for testing?
I still plan on following the repair manual and checking it with Multimeter to see if its just a bad sensor...like I said I've had problems with it earlier...
And I'm about 95% sure jumpers are set correct, especially since this is a new issue...
Old Jan 19, 2010 | 12:23 AM
blown_xa's Avatar
I think it is the primary 02 that is causing the bouncy idle. Fuel trims are going back and forth. Unplug primary 1st. Expect code Bank 1 sensor 1 02 circuit low/high output I think.
Old Jan 19, 2010 | 12:35 AM
maybe p0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
Old Jan 19, 2010 | 03:48 AM
Hix's Avatar
Hix
pee on it
