Custom Supercharger Shafts !
#1001
how many shafts did you sell in the end.
also is there an identifier to tell if the supercharger already has the shaft?
#1006
Its up to you, if you have time and money to blow then have fun, if not turbo will suit you better. After going both ways, i'd just pick a different car, in going through an S/C, 2 Turbo setups, and 2 engines, I found the 2AZ-FE isn't the best platform for forced induction in general.
____________
#1007
This doesn't address the Achilles heel of the s/c, which is the shaft/pulley side of things, which is not a good design and I wouldn't trust it, its still best to get rid of the problem all together and go turbo. In addition to this s/c parts are becoming harder and harder to find. Its up to you, if you have time and money to blow then have fun, if not turbo will suit you better. After going both ways, i'd just pick a different car, in going through an s/c, 2 turbo setups, and 2 engines, I found the 2az-fe isn't the best platform for forced induction in general.
besides, with the right bearings and a remade shaft, what is left really?
and I did pick a different platform lol, its a 1991 MR2 with the 2AZ.
#1008
there are many other engines that support F/I much better. In my experience the 2AZ has PCV issues when using F/I.
___________
#1009
The design is bad all together, a grease fitting and cooling will help, but no matter what bears you get, i would replace them yearly if you are aggressive with the car, the 2az-fe in the scion is not the best engine for f/i, there are many other engines that support f/i much better. In my experience the 2az has pcv issues when using f/i.
*Edit I should explain, I got this supercharger for $300, I think its worth it to pump $1000 into getting the shaft in order, because this is a smog legal setup.
#1010
website works for me.... the main problem is the bearings, once they go bad they lock up and the shaft starts spinning inside of the bearings which causes damaged to it. So its the design of the bearings/housing more so than the shaft itself. My shaft was a replacement for shafts that had already been damaged, if yours is not, then do whatever you can to keep it that way.
#1011
so if you use the ceramic bearings how long do they last?
ok sorry I was using the link in the first post.
#1012
The shaft side doesn't not spin fast enough to warrant ceramic bearings, they won't last any longer than steel bearings. It depends on heat and load and luck. Some people have gone a year, 2, 5, 6 months. Have to keep an eye on it and make sure you keep it cool and install a grease fitting. Ideally take it apart every year and take a look at what is going on.
#1013
but it just takes checking up with it every year or so?
#1014
Ceramic generates less heat because of friction, but that is at very high speed. It is not worth the money for the shaft side of things, very minimal benefit. If you check yearly and every time something doesn't sound right, you should be ok. The grease fitting is the best mod you can do imho.
#1015
I dont understand the benefits of the grease fitting. are you saying the shaft consumes grease and needs to be topped off every once in awhile?
#1016
the grease in the bearings liquefies and gets thrown out of the bearings because of centrifugal force. So yes packing the space between the bearings with grease lets new grease get into the bearings. The grease leaks out of the shaft side housing slowly over time.
#1019
I agree with gompka, at this point in the 1st gen tC's life, nobody should really be looking at the supercharger as an option, no matter how cheap the kit was, there is a reason for that.
Especially with the kits most people will be running across will be used and who really knows what kind of state it may be in. even if it was new, you have to be very careful with install since that was a big problem with the kits failing.
with all that said, 7+ years now my S/C is running fine on the 9.5lb boost pulley and I do have the gompka shaft.
it's my daily driver and I am NOT running this car for speed runs at a track, just fun cruising.
every couple years you need to change the belt and an idler or tensioner pulley, but that is the only extra maintenance I would say i have to do because of the supercharger.
My experience is definitely not the norm, and i firmly believe the reason is because I was never looking to race everything or to everywhere.
#1020
I am looking to purchase one of these shafts or the shaft with bracket assemblies or possibly the complete supercharger assembly PTR41-21165 with upgraded shaft if anyone has one floating around. Thanks.
