DIY-AEM F/IC-now with 2-Step launch control
#104
#106
That wire that we are cuting doesnt go to the ECU...this wire is coil power, so we are not trying to affect the signal, we are just steight up killing power from all of the coils.
#111
there is a flaw with doing it this way, anytime you clutch in after launch will initiate the rpm limit cause there is no switch that will shut the limit off at a certain speed...the cool part about that though is if you leave the rpm limit to around 4000rpms all you have to do is clutch in and leave your foot on the gas, it will limit you from going past 4000rpm or under 4000rpms...so in a sense you have no lift shift!
#113
#118
not yet..im not going to do it on a customers car but ill do it to mine...id feel really bad if anything went wrong. I'm still buying things to complete my setup so maybe in a month or two i may have some updates.
