emanage problem need help... throwing error codes
i just hooked my emanage with injector harness and ignition harness but for some reason when i try start the car the car would start up it will crank but wont start up...could some on give me some wiring diagram of the car as it is in the car like picture of emanage wiring the you did with out the pnp harness b/c i want see if i wired it up right and i think i wired it up wrong...but when i pulled the ignition and injector harness off the car emanage still reads an error code even from the main harness that i hooked up a month ago..i dont know wats wrong i m so lost and tired i been working on the car for 7 hours on wiring harness and it getting very frustrating....thanks if any one could help me out....
no i havent tried that, i was frustrated with it so i removed the ignition and harness off and the injector and now it throwing a error code from the main harness...and the error code that i read was 12 which was airflow output or in put i dont remenber but i didnt have these problem before when i first install the main harness i dont know wats going on but i will try see if that works i dont have time right now so i m going to redo all my wiring when i get done with finals thanks
for the advice i will try that and take some picture so some one can help me out
cid_mcdp
Jan 5, 2015 02:45 PM
rcflyer15
Dec 5, 2014 05:15 PM
