Greddy 18g turbo max wastegate psi
Old Dec 21, 2012 | 05:54 AM
SuperWhiteTc06x's Avatar
Default Greddy 18g turbo max wastegate psi
Hey guys I'm curious at what psi does the wastegate actuator open and what is the max boost that you can usually hold without a boost controller? Looking for people who run the turbo and experienced it because right now Im only holding 6 psi and supposedly I should hold around 8.5 psi. I called Greddy and they said that I should be around 8.5 psi, but I've read some posts around the forum that say it is necessary to get a boost controller to boost past 6 psi. I'm not sure if I have a boost leak or not and would like some clarification.
Thanks
Old Dec 26, 2012 | 05:35 AM
Sparky7's Avatar
Get a vacuum/psi tester thingy. It's a hand pump thing that's clear and has a gauge on it to measure inches of mercury (vacuum) or pressure (psi). That will let you pump pressure into your waste gate actuator and physically see when it opens. Awesome tool to have.
Flyfishfreak
Jun 10, 2016 02:55 AM
cessblood
Sep 15, 2015 06:50 AM
brett561tc
Sep 15, 2015 06:33 AM
xa007xa
Mar 31, 2015 09:24 PM
B_Real45
Feb 23, 2015 07:33 PM
