HELP!!!!!!!!
HELP!!!!!!!!
I have a 07 scion tc thats has been turboed ...... Has a cyl 2 and some time 1 missfire ......when i get over 4500 rmp it starts to miss real bad and i have to let off and let the cel stop flashing then i can give gas again ....... Have changed plugs and coils .... Compression is from 1-4 155-160-158-155 any idea what the problem is?
It's either the tune, or it is picking up noise on the crank/cam singals. Search these forums for the AEM FIC setup thread. It should tell you everything you need to know, including the "resistor mod" that might be required if it's not already done.
Yea it could be the install of the tuning hardware (aem fic)
Or its the tune itself. You might wanna check around some more and see if you can find someone not to far from you to take a lot at it.
It wouldnt be safe to keep driving it without knowing what the problem is. could burn out the motor.
