help with emanage ultimate
hey i have an 04 tc with the greddy tdo5 18g turbo kit, 550cc inj, and an emanage ultimate. i am having all kinds of problems with the tune. does anybody have a good downloadable tune out there? i spent 600.00 on a dyno tune a few months ago and hit 300hp and 340 ftlbs of tq at 10 pounds of boost. my problem now is the emanage will not keep the tune and it is getting expensive. i have decent knoledge about all of this i just dont know what numbers to punch in the maps to get it to run better. :bow: :bow:
if you have already been dyno tuned, your map should be loaded on the emanage and you should be able to pull it up through the program and your computer. And you spent 600 on the tune?! Tell me you live in cali cuz i will send you somewhere a lot cheaper over by long beach
are you having problems with the ECU fighting the tune?
if you must, disconnect the primary o2 sensor to throw the ecu into limp mode, which is a very conservative fuel map, and then tune that. you'll have a CEL on non-stop, but the ecu won't be able to re-learn so the tune will stick. |
