help with Fuel return system
Im looking to get a fuel return system for my boosted tc,i know ptuning has one and dezod has one as well.anyone know which is better? Or if there a better one out there?or better solution like custom making a kit.
I have the Dezod fuel return system, A friend of mine has the Ptuning fuel return system. They both work flawlessly. Either one would be a good choice.
We're offering 5% off of any online purchase over $100 through the end of the month. Food for thought.
http://www.dezod.com/pd-return-fuel-system-tc-05-10.cfm |
speaking of fuel return paul, does it come with a new sending unit or do u have to drill out the existing?
Originally Posted by PeArLwHiTe07tC
(Post 3950460)
yeah thats kinda what i figured. i found the diy on dezods site. the way it makes it seems, as if it comes with the sender too. no biggie, ill just buy another one.
(Post 3950467)
I already have the walbro fuel pump i think i saw on your site that its like 70 dollars cheaper without it correct?
How much boost are you running with the kit boostit06?
Originally Posted by kimbym05
(Post 3950509)
(Post 3950511)
Sweet im guessing ur built..im on stock motor oí wanna try and boost 11psi
Yep built motor. The fuel return system will really allow you to expand.
Originally Posted by BOOSTit06
(Post 3950647)
WORD!!! consider this, on 550cc injectors and stock fuel system I maxed out the injectors at 12psi (iv done 14psi on stock fuel system however leaks screwed up airflow), now on the same exact turbo system along with a dezod return fuel system (using dw 300lph fuel pump) im able to boost 23psi on 550cc injectors @93psi peak fuel pressure. upping fuel pressure is key to get the most from your injectors |
Damn sick...i deff need one . plus im running ethanol so i need it even more lol.....i want one!!!!
| All times are GMT. The time now is 10:34 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
