help me!
550-700 will be fine for that power goal..
550cc will be close to maxing out, to help keep it from maxing out you could add a fuel pump for another 100 bux. It will help keep a hearty flow of fuel to the injectors and keep the pressure up to snuff. this inturn will make your smaller injectors be able to keep up with the demand.
700cc i think will just perfect for your app, it will give you just a little room for extra boost.
Carlanga has a similar turbo and he is boosting 9psi using 700cc injectors and a walbro fuel pump. his duty cycle is 60-70% (cant remember which). you dont want to go over 80% duty cycle on your injectors. The reason being youll have poor fueling conditions that will hurt your power and run lean. also you could do harm to the injectors themself.
