help with turbonetics turbo kit (noob questions)
Old 08-11-2014, 03:25 PM
blaze1119's Avatar
Default help with turbonetics turbo kit (noob questions)
Hello all i am new to force induction and wanted to purchase a turbonetics kit from here: Scion tC Turbo Kit- TREADSTONE PERFORMANCE
and was wondering other than getting the AEM FIC controller and fuel injectors what other things will i need?
also will i still need a tune after installing the fuel injector controller?if not is it still recommended.?
blaze1119 is offline
Old 08-11-2014, 03:51 PM
FlintMica17's Avatar
Depending on what year you have, this is straight from the link you posted:
04-06 will come with Uni chip, 07-10 will come with AEM FIC and boomslang PnP harness. AEM will needing fine tuning of base map, we will provide base map. "
You may want to give them a call regarding the "no fuel components included comments"
You will get a base tune with AEM (assuming you drive and 07-10). You'll need to get an actual tune once the install is finished. Injectors are included in that kit already.
FlintMica17 is offline
Old 08-11-2014, 03:56 PM
blaze1119's Avatar
Thanks flint, i will give them a call to see some of the details of the kit.
Old 08-11-2014, 10:01 PM
burgandybomber's Avatar
Scion tC Turbo Kit Tuning & Fuel Components- TREADSTONE PERFORMANCE
That is the link for the fueling components. I would also check with Paul at Dezod and see if he can hook you up. I think he was running free gauges with an FIC? I could also be full of it lol.
burgandybomber is offline
Old 08-12-2014, 01:04 PM
blaze1119's Avatar
Where can i contact paul from dezod? via phone or i can shoot him an email?
Old 08-12-2014, 01:14 PM
Scionetics
KAD
paul_dezod's Avatar
That kit is all smoke and mirrors. Selling a kit without fuel and engine management which will equate to $1000 more in cost puts you at our pricing (roughly) and you with our kit, you get a better quality system all around and support!
Scion tC turbo for 2005-2010
paul_dezod is offline
Old 08-12-2014, 01:51 PM
^^^what he said haha
Old 08-12-2014, 01:52 PM
blaze1119's Avatar
thanks paul with the link and the advice, and yes i believe your brand of turbo's is high quality. i have a question is it possible to buy the kit the parts. so fuel and engine management 2000 and the rest for another 2000?
Old 08-12-2014, 09:12 PM
Save up or get a loan. Its worth the boost!
Old 08-13-2014, 01:43 PM
blaze1119's Avatar
k see you guys in 2 months hopefully fully boosted and working well
Old 08-13-2014, 01:44 PM
Looking forward to it!
Old 08-13-2014, 04:15 PM
Good luck bud. Keep us posted.
Old 08-14-2014, 01:13 AM
That_Kid_Ju's Avatar
Don't forget about upgrading the clutch. You won't last long on the stock clutch. You'll also need at the bare minimum a wideband AFR and boost gauges. Eventually, you'll wanna upgrade the exhaust (if you haven't already) cuz the stock exhaust will leave you wanting more. Plan for at least $6-6.5k to start (Turbo kit, clutch + install, gauges, and tune), then about another $400-$900 for a catback exhaust depending on which one you go with.
That_Kid_Ju is offline
Old 08-14-2014, 01:22 AM
blaze1119's Avatar
i have an exaust already and the gauges boost and AFR, but i changed my clutch 1 year ago and didnt want to change again for a bit longer. how long do you think the OEM exedy clutch will last?
Old 08-14-2014, 02:59 AM
Depends on your driving style. Could be a few days or could be months. Might even start slipping durning the tune. You'll definitely wanna have something to hold the power and torque range you want to target. I'll tell you from experience: go with something that canhold more than your turbo can put out. I've changed clutch 3 times since going F/I.
Old 08-14-2014, 01:20 PM
Which is why I bought the CC Stage 4 lol. Its heavy but it holds!
My brand new stock clutch died in about 2 weeks. I could get MAYBE one run at the track if it was cool to start with. There are some pics in my thread of the disk. It had turned all sorts of purple from the heat.
Old 08-14-2014, 01:25 PM
I had the CC stage 4 for ~ 44k miles. Was so stiff it blew my clutch master twice. After taking it out, found one of the spring seats (dont know the proper term) started cracking. If I woulda kept it, trans woulda likely suffered from clutch blowing up. Using ACT 6 puck now. Lighter pedal feel and more torque capacity.
Old 08-14-2014, 01:27 PM
blaze1119's Avatar
SO the CC clutch stage 4 how long have you had it i n your car? and have you had any problems
Old 08-14-2014, 01:29 PM
Yeah my throwout is bad so eventually this clutch will get replaced with an ACT. My master is probably going too. If I can, Id like to just replace the pressure plate. The disk is still good.
Old 08-14-2014, 01:39 PM
blaze1119's Avatar
hhhmmm, so what is a safe clutch to install that can handle the power but not cause any other headache?
Quick Reply: help with turbonetics turbo kit (noob questions)
