How much boost can a stock 2AE-FE handle?
I currently have a custom piping and exhaust manifold setup but I wanna know how much boost a 2005 scion tc engine with 71k miles will hold. Looking to put 50mm wastegate and 12 psi. Currently at 8PSI Don't worry about traction, I got brand new NT555's all around. Car slips a little if I launch like an evo and second gear BARLEY slips with cold tires and doesn't slip at all when warmed up. Car will most likely be street tuned and not being tuned at UMS! They suck!
Under the hood and current setup:
Paul is right on the dot. I say once you go past 310whp even on a good tune it becomes a ticking bomb. Eventually a rod is going to give, I got two engines to prove it :-( My tC is currently sitting in the garage waiting for funds to get a long or short block depending on the head condition and build it up. Aiming for 500whp
Pistons and rods will suffice for 500+hp on whatever boost, well over 12+ that's for sure, just as long as compression is 9:1 or close that way it's safe. Just building bottom end is fine. Although you don't need to build the head, the head should be machined and completely cleaned with a valve job and valve guides and bowl work. And yes, 500+ is a trans breaker. Ask Black Knight.
Why on earth would you put it in first at 12mph? Stock first gear shouldn't even have it put in unless you're stopped. Of course it's going to grind. It should be locking you out actually, so you really must be jamming it in there. I would advise against that.
I'm pretty sure mine is just messed up :l I drove my brother's cobalt ss recently. my jesus, it is soo easy to drive compared to mine. Very light clutch pedal and easy smooth steering.
GM actually did a real good job on the Cobalts. Factory turbo will always be better than N/A-T. Night and day. However, with N/A-T, you get the satisfaction of "built not bought"
Have you even watched TFATF? The built not bought is saying it's better to have a lower end car with a built engine and transmission than it is to buy a lambo or ferrari that comes stock 500 hp.
I am playing around in the 7-9 psi range right now (a little under 4k miles) till I get new tires. Which speaking of tires, what size are you running? I cant find anything for a 17 that would fit in the NT555's. Looking at the Continental Extreme Contact DW right now because I was very satisfied with the DWS when it was stock. I really want the Michelin Pilot Sport's but the 140 dollar savings can buy more stuff lol.
Its an absurdly nice little car for the Big Bowtie to have made, but there is one thing that you can never change. Its still a Cobalt...
The expression you get from cars that cost twice as much are twice as nice lol. Youll usually see or maybe , and sometimes .
What up Burgandy!! Where you been homie! Bump your thread and let's see what's going on!
just keep it at 8 psi until u build the bottom end. your going to break SH*t on the stock long block. and you can talk to dezod and ptunning for all your power need these guys have everything u need.
spawnconnery
12-18-2014 08:38 PM
darkshadowofxdeath
12-03-2014 06:59 PM
