Just an idea - Additional Injector
This is just an idea I had and im still thinking on it looking for some scionlife creative minds input
Ok this is our situation - we all have these build bottom ends and were on pump gas..
Were stuck at that 400-450hp mark but we want some more.. maybe 500
We can get meth injection to get a few more psi safetly on pump .. but everyone has that lets think outside the box
e85 isnt available enough to be a primary fuel
we dont want to be switching maps and fuels left and right
lets say were running a piggyback with a few outputs
heres a new idea i like doing things different and trying new things
lets put another injector in your charge piping a few inches before the throttle body.. these are the parts im thinking about
1-2 gallon fuel cell in engine bay
walbro inline fuel pump
ATP Turbo sells a kit to fit an injector on an IC pipe
put a stock injector in it really shouldnt matter
fuel pressure vs return? dont know yet?
Lets put C16 or E85 in the fuel cell for a little octane boost
The main concern - controlling the injector
teeing into one of the 4 injectors would throw off the signal - cant do that
buying a new control box - too much $
running off a hobbs boost switch - RPM/TPS is too much of a variable as cheap as it would be - would work with a supercharger
Using one of the outputs of the emanage ultimate - looking up this option now - it would work perfectly
if we can use our existing ECU to control the injector this option would probably be cheaper and more reliable than a meth kit
just a late night idea - any thoughts?
ill stick to ethanol.
my opinion is....if someone wants 500 hp they should be able to afford methanol and run enough boost to hit 500hp. also, if your wanting 500hp cheap isnt in my vocabulary.
rule #1: dont boost on a budget.
butttt, i do give you probs for thinking outside the box. i say do it and post results.
hey sorry dude but... i bleive jessica is making 700 on pump gas and no meth....
anyways... your theory has its flaws...a much smarter approach would be to run a fuel nozzle ffrom a nitrous kit into the charge pipe and have a fuel selonoid connected to the fuel rail and the nozzle... and boom u have fuel when u want it and at the exact amount u set it to... cheap and works
I didnt meant to come off as cheap at all.. Nobody said to boost on a budget.
Finding inexpensive ways to get more power is different.
I was just thinking of maybe an alternative to meth injection.. im tired of pumps failing
LMAO shes not on pump are you insane
Turn ur boost to 35+PSI on pump and see what happens
How can u set how much fuel is spraying and when?
im guess by the size of the jet or another fpr. i guess you could compare it somehow to a couple of different injectors to see what jet size is equivalent to what injector size.
my question isn't that far off topic for this thread....
I have seen this in other threads where those that go F/I .... that some switch over to E85. Just curious what the actual advantage or need to run E85 once boosted.
thanks!
thanks!
the amount of fuel u add is determined by size of the jet, and u can then further subtract or add fuel to your regular injectors...
and also most piggy backs support the trigger feature so at certaim rpm u can trigger this selonoid to fuel...and then cut off before rev cut cuz fuel in intake manifold and revlimiter = boom
local gas station here has c16 but anyways... play nice gingles...
e85 is very high octane, this reduces knock/detonation drastically and keeps things cool only problem is u use almost twice as much e85 than gas for 1 spark
i was under impression she was on pump....
e85 is like crack... you can add gobs of timing running ethanol and not have detonation. e85 is like 110 octane i believe.
cburgl......do you know anyone that is making 700hp via pump gas on a 4cyl?
the fuel selonoid is electronic and u can either use a windowswitch that cost liek 300 dollars tio activate during WOT and certain rpms...
or i know aem fic lets u turn on nitrous selonoids at certain throttle positions and rpms as well as cut off
