need help/advice on removing a supercharger bolt!
Old Mar 10, 2013 | 03:42 PM
youngflyer's Avatar
Default need help/advice on removing a supercharger bolt!
hey everyone i starting trying to rebuild my supercharger myself. i was going to do it at my job (mercedes) but the shop foreman didnt want the liability. so im stuck doing it at my house with sub par tools.
There is a 6MM allen bolt with a half moon head on it that holds the pulley side bracket in. i didnt have a 6MM ratcheting socket so i attempted to use a allen key instead. it ended up rounding off the bolt and im kind of lost on how to get it out. it looks like a terrible place to try to get a drill bit in.
Old Mar 12, 2013 | 04:45 AM
youngflyer's Avatar
bump any help?
Old Mar 13, 2013 | 02:02 PM
vi3tb0i09's Avatar
I don't remember any half moon bolt on the pulley side. Do you have the 05-06 or 07-10 kit? A picture would help too.
Old Mar 14, 2013 | 01:37 AM
youngflyer's Avatar
i have an 05-06 ill try to snag a picture tomorrow but i think i decided to just hand it over to P-Tuning and let them deal with it!
Old Mar 14, 2013 | 02:18 AM
scion86's Avatar
Yeah snap a pic. I just recently took apart my sc with no probs.
Sent from my SGH-T999
Old Mar 14, 2013 | 02:56 AM
AZGuy's Avatar
Post a picture of the offending item.
Old Mar 14, 2013 | 09:06 PM
cmcpride's Avatar
he means the bolt head is rounded like a 1/2 moon, there are two best ways to remove, might sound stupid, but the best way . first you could purchase a reverse extractor from sears, or snap on,, they sell different sizes. and attempt to remove it might be tough since the head is rounded like a half noon, other way, get a chisel longer the better. and make a straight mark beeper the better, and i do mean straight do not attempt to mark at an angle since you might chip the bolt and it makes it harder to remove, once you mark it then apply wd40, on the bolt try not to apply near the mark, let it sit for a few min then attempt to softly hit the mark at a 35 or 45 degree angle, it should loosen up..
Old Mar 18, 2013 | 01:47 PM
gompka's Avatar
This is what i would do also, its a very tight fit there, might be able to drill it with a 90 degree drill but I would say that is last resort.
Old Mar 20, 2013 | 01:25 AM
youngflyer's Avatar
Thanks for the advice guys. I just took it to ptuning and they fixed it
Old Mar 20, 2013 | 01:54 PM
RS2Blitz's Avatar
I'm having this same problem. Did PTuning tell you how they fixed it because I need to know as well?
Old Mar 21, 2013 | 02:34 AM
jacob81's Avatar
try the bolt extractors like stated above. You could also attempt to use vice grips if there is enough of the bolt sticking out and lastly, you can weld a nut to the top of the bolt and turn it out.
Old Mar 21, 2013 | 04:15 AM
youngflyer's Avatar
no...my shop wouldnt let me do it there so i just put the whole thing back together and brought it to ptuning and they did a great job fixing it!
Old Mar 22, 2013 | 02:19 AM
blown_xa's Avatar
I used a cut-off wheel and ground the head down, removed the assembly, and was able to remove bolt stud with my fingers. Im glad you are satisfied with the rebuild! Sounds quiet.
Old Mar 22, 2013 | 05:17 AM
youngflyer's Avatar
very satisfied with the rebuild!!! i was a hesitant spending 1600 for the rebuild when i was told there was only a 60-70% success rate but im very relieved now. when i picked it up it was idling horrible and shut off a few times but i guess it was the ecu readjusting itself because after the hour drive home, it was running better than ever. no more backfiring, no inconsistent idle, no loud bearing noises, no more damn headache haha! i really appreciate yall putting the grease fitting in as well!
Old Mar 23, 2013 | 10:17 PM
blown_xa's Avatar
The low idle was most likely caused by built up gunk around the throttle body plate, battery was disconnected during rebuild and default throttle postion was too low. Remove the throttle body and clean it with carb cleaner and toothbrush. Hold plate in open postion with fingers and scrub it. Your airbox isnt sealing, that could be part of the excessive gunk
Old Mar 25, 2013 | 03:50 AM
youngflyer's Avatar
i will do that, do i need to take the throttle body off the car to clean it or just take the intake piping off? and i have noticed before my airbox isnt sealing properly, any idea why or where to get an aftermarket one (maybe you carry one?) and i also noticed the o-ring around the maf was torn so i replaced it and hopefully that will help a bit!
I have some more work that needs to be done so you will probably see my car in the shop soonish!
k1114
43
Mar 1, 2023 03:08 AM
Greg S
Jul 21, 2016 07:28 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
mickkassem
May 12, 2015 03:36 AM
SpaceCaptain
May 11, 2015 06:24 PM
