Removing s/c and going back to stock. HELP
Hi, My supercharger has been damaged for years now and I still drive it. It has about 70k miles on it and I am thinking about going back to stock instead of repairing it or replacing with a turbo kit to save money.
I have all the stock parts except the stock injectors (damn dealer lost them)
Also if they did any computer work then I also do not have that stuff either.
Will the car be ok running on the trd injectors? Do I need to do anything to the computer to make it stock again?
I need to do asap cause im out of working vehicles.
Jason, I am going to just re-post what I said earlier about this and others can chime in. For a temporary fix, you can take off your s/c, put on your stock drive belt, plug the oil lines, and use your stock intake. The car will run, it will be running pretty rich and will be bogged down at low speed, but it will run.
Later on, you will need to get some stock injectors. I may actually have a set I can sell you for dirt cheap, I will have to look for them. Also, you will need to go online or a junk yard and find a new computer, it will have to be from the same year t/c and either manual or automatic depending on what your car is. Then you can use the tutorial on here to program your key transponder to the new computer. Then after that there is the oil pan, spark plugs, and thermostat.
It is a 2006 Auto.
I'm ready to take it back to stock and get it running right then probably try to sell some of the parts and trade the car in.
Gompka: How much would you sell your injectors for?
Also does anyone have a computer?
ok so far heres what I know I will need:
-stock injectors
-stock computer
-stock spark plugs
-thermostat
-I have all the other stock parts I believe. Including oil pan, belt, intake, and different hoses and stuff.
-stock injectors
-stock computer
-stock spark plugs
-thermostat
ColonelSanders85
Dec 9, 2020 09:44 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
fluxingnation
Dec 26, 2014 04:28 PM
