Sputtering and hesitating
well i got tuned this past saturday and as of monday my car started acting up the car would sputter and hesitate under boost
AFR? Which EMS?
AEM F/IC and i dont have a wideband but its on the way as we speak
Just curious does it get really rich (down to 10-11.5 afr) and sputter around 2krpm when under vacuum and partial acceleration? DOnt really understand this but i dont know if youd ever see this on a dyno tune - i had to pull fuel in this range to fix it, now it works great after a little tweaking
he probably won't know until he gets his gauge.
you're afr's are probably around 10.0 or lower and you are running really rich. past 2k rpm how is the car? |
take out a spark plug.. takea pic of the tip and post it
I'd bet one of your pipes on the boost side has come loose.
pull the plugs and they are still good ... its my fuel map its running rich in boost and partial acc. it was doing this on the dyno but i thought the tuner would have fix it.
what was the a/f you were getting while on the dyno then?
to be honest im not real sure but i wanna say 11.5
whats vacuum at during idle
This happens sometimes after a dyno tune, it is probably running rich, get that AFR gauge installed.
If you didn't, then we don't know what your gap is.. but the gap could be your issue. |
Just curious what should our plugs be gapped to? .040? Im using ngk iridium's that are -11 so theyre .044 stock i believe :)
Okay - try making a smaller gap.. try .35 first.
i dont have a gap tool and i know using a slider gap tool isn't very smart for iridiums .. and part stores around my area dont have a clue about the tool i would need
If you want, go out and buy regular copper plugs in 7 heat range and gap them down.
