[Help] Boost Pressure Too Low
Old 12-24-2012, 05:11 PM
tootles23's Avatar
Default [Help] Boost Pressure Too Low
My engine load gauge on the FIC is reading at around 6.5 psia, which is wayyy too low. My map doesn't even account for load that low. When I get up to around 6.5k rpm, the load gauge shoots up to maybe 9 psia, then drops back down to 6. I'm pretty sure I tapped the brake booster line. My methods were ____ty at best, and I'll pick up a vac block eventually, but I don't think it would affect my readings.
I just finished my turbo install, and this is the only thing holding me from hitting the road. Please Help!
I can attach a log too if that helps.
tootles23 is offline
Old 12-24-2012, 07:55 PM
Kidbarillas's Avatar
You might have a leak
Try using a clamp
Kidbarillas is offline
Old 12-24-2012, 10:18 PM
BadDudeTC3's Avatar
I would start by clamping down the lines with small worm clamps and getting a vac block ASAP.
BadDudeTC3 is offline
Old 12-26-2012, 01:49 PM
That_Kid_Ju's Avatar
Definitely sounds like a leak. Check the silicone couplers to make sure one didn't pop off. Do you hear your BOV nice and loud? If not, then a leak before the BOV (that happened to me the first time). Also check the coupler to the throttle body. That was a PITA to get on and would slip off at the beginning.
That_Kid_Ju is offline
k1114
43
03-01-2023 03:08 AM
Sooby
Scion tC 1G Wheel & Tire
11
04-08-2020 11:51 PM
my06tc
06-25-2015 12:18 AM
Zombiecustoms
04-19-2015 11:13 PM
jctc06
04-16-2015 12:11 AM
Quick Reply: [Help] Boost Pressure Too Low
