TRD Supercharger HEAT!
I'm getting a bit worried about the heat that I'm feeling on my supercharger after normal driving. I haven't been able to get a temp reading yet, but I CANNOT leave my hand on the bearing casing or the compressor housing for more than half a second, maybe a full second- it's that hot. Is this how it's supposed to be? I'd really like to figure this out BEFORE my bearings let loose...
Also, if this is how it was designed, it seems like there's an awful lot of heat making it's way to intake air, and negating some of the positive effects of the boost...
yes, it is supposed to get hot.
1. it is compressing air, compressing air generates heat.
2. it is in an engine compartment right next to the exhaust manifold, which is also very hot. so yeah, radiant heat too.
PS: This is my 3000th post!!!
Good point. If you are going to do that, I would suggest getting an oil cooler to take full advantage of the hood vents. I have mine and love it. When I went to scion united in vegas, my oil temps didn't go above 185-195 (even when it was 100+ outside)
exhaust heat can be solved by heat wrap(steel headers only), oil cooler for the oil heat, better radiator/fan combo for coolant temps, trans cooler if its auto, cai for intake heat, and meth injection, i wish they made ram-air aftermarket hoods, looking into buying a low profile scoop and having it molded and painted like factory to help with the heat issue
I realize that compressing air generates heat, and that there's heat under the hood, but the supercharger heat seems excessive.
Based on what I've seen, the supercharger pulls oil into the bearing casing from the oil pan on startup, but there's no oil circulation- it simply uses the oil that it pulls for lubrication, and pulls more if it needs it (i.e. oil breaks down) Please correct me if this is wrong.
I'd love to use an oil cooler for the supercharger, but based on how the supercharger uses oil, it seems that the effect would be very small at best.
Is anyone using an oil cooler with the NST 9.5 pulley, and what are your results? Also, does this cause the A/F ratio to drop too low at WOT?
Start with an oil cooler setup
Then work on hood vents or engine bay air flow
Then move on to coating your header or a headsheild/heatwrap
I wouldn't work on boosting more out of the S/C until you can better manage the heat, otherwise it will be a quick death to seals, bearings, etc...
RS2Blitz
Jan 15, 2016 09:41 PM
