Turbo install help
Does anybody have turbo install instructions for any TT kits. I dont have any instructions and just have a basic idea of how its going to go. Any instructions will help out a lot as this is my first install and I have one of the older not perfect fitting kits as well :flame: . You can Pm me or email me at fury575@hotmail.com with any possible help at all. Thanks!
which kit do you have?
Im pretty sure its the 2.1 version, not the log manifold and its the older intercooler setup
For the manifold will the stock bolts hold up for that or should i purchase stronger bolts
the stock studs will work but if it makes you feel better then go for the dezod extended head studs.
Thanks
The install is pretty much the same, as long as you get the concept. Now if your pipes fit well thats gonna be the challenge when you need to modify it..
You can start with the most difficult stuff like taking out the oil pan then installing the HKS bov on the flange lol.. then fit the intercooler.. dont try tighten bolts right away, get things to line up perfect first.. |
