turbo spark plug info
.029-.031 gap 1step colder plugs
example; ngk brand bkr7eix
personaly i run 2 step colder with .029 ngk brand bkr8eix (they come pregapped .029-.030)...always check the gap to make sure but its pretty hard for them to get mishandled (not saying it cant happen) to were they will need to be gap'd more or less. most plugs are packaged with sleeves to protect the ground strap.
I run these cause of the amount of boost i was running (any given day may run 16psi which would put me somplace in the mid 300hp range on my t3/t4b garrett)
I was wondering... Those of you on 18-20 psi what are you running gap wise? And is anyone having spark blow out issues? Im gapped at .025 on my copper 2 step colder with E85 on 18-20 psi, wonder if i could go with a bigger gap, i was just afraid of getting spark blowout
not copper but its the cheapest plug i could find that is one step colder that fits our car
http://www.ngk.com/results_cross.asp...KR7E&x=80&y=25
btw almost all ngk plugs part numbers start with bk except for the laser iridium plugs
found it
http://www.ngk.com/more_info.asp?AAIA=&pid=32413
problem is its gapped to .044...so you will need to regap it a bit closer... .030 should work, you can always adjust to what works best for your app..good luck
Sry ment stock number not part number... price isn't the prob I just want to run the best plug and with my roommate working at checker ill get life time warrenty I could get new plugs every month so I'm trying to run the best..
I've been wondering the cooper deal myself, wouldn't mind getting 2-step colder cooper plugs. I don't care if I have to replace them every 20-25k miles, heck I change the iridiums almost that often anyways (peace of mind)
You can run either, but I would not recommend bouncing between each copper and iridium. The tune requirements change for each plug.
Also, we sell both kinds at our store. Order with Ground shipment and as always, we overnight them for free!
http://www.dezod.com/cat-spark-plugs.cfm
my06tc
06-25-2015 12:18 AM
daniinpitt
04-04-2015 08:07 PM
cid_mcdp
01-05-2015 02:45 PM
06ScionTc5sp1
18
12-21-2014 07:21 AM
gap, gape, gapping, iridium, plug, plugs, recomendation, scion, spark, sparkplug, step, supercharger, tc, turbo, turbocharger
