Turbonetics check engine light need your help.
So I pulled my plug n play harness, and so far I noticed that my TPS wire / 22 Pin connector pin # 6 is going in to E8-21 and not E8-20 on the ecu pin out. O2 1 sensor wire / 24 Pin connector pin #13 is going to E8-20 and not E8-21 on the ecu pin out.
E8-20 on the pin out for the ecu is TPS, and E8-21 on the pin out for the ecu is A/F sensor. Im not sure if this would be causing the problem or not, what do you think.
I only noticed cause the scangauge said your stuck in open loop no matter what i tried to do. glad i had it still, almost sold it a while back....little sucker has come in handy.
Maybe break the motor in first? lol I'm down for Thursday or Friday to turns some wrenches and bust up some knuckles getting the motor in. Just call me when you get it all figured out.
As a further testament to that, for the first time since I've been boosted, no check engine lights! Even after 2k miles of his tune! It's amazing what a Scangauge will do for you if you have one to tune with!
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
