Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion tC 1G Forced Induction (https://www.scionlife.com/forums/scion-tc-1g-forced-induction-1645/)
-   -   Valve cover leak :/ (https://www.scionlife.com/forums/scion-tc-1g-forced-induction-1645/valve-cover-leak-163623/)
BOOSTit06 May 29, 2009 09:18 PM
Valve cover leak :/
So I have been having this problem with my valve cover leaking, I have replaced it twice and put a check valve in but still no success, I am running a zpi kit on 11lbs with a 20g turbo. Anybody else run into this problem? Help would be much appreciated.
Ace83 May 29, 2009 09:42 PM
valve cover is leaking oil? did you change the gasket?
JBT89 May 29, 2009 09:48 PM
did u make sure that valve cover gasket wasnt mis aligned b4 u closed it offf
TheFantasticG May 29, 2009 09:50 PM
Has the engine over heated before?
BOOSTit06 May 29, 2009 10:15 PM
No the engine has never overheated, it is a very small leak, The gasket has been properly installed, Im just not sure :/
Ace83 May 29, 2009 10:49 PM
do you have a new gasket or reused it?
BOOSTit06 May 30, 2009 12:25 AM
no it is a new gasket, I looked at it closer tonight and I think there might be a hairline crack in it :/
© 2026 MH Sub I, LLC dba Internet Brands
