Weird Boost Problem*NEW PROBLEM*
Old May 27, 2008 | 04:55 AM
NVMyTc's Avatar
Default Weird Boost Problem*NEW PROBLEM*
So today on my way to the movies, an S2000 wanted to run me. So we went from a stop. I babied first gear, hit second gear perfect, but still was feathering the gas (had a 1/2 car on the guy) then finally had enough traction to floor it. I floored it and started to pull then all of a sudden, my car just stops like if I let off the gas but my foot was still to the floor. After about 1 second my car picked up again like if nothing happened.
I am on my stock clutch still and i'm making 270 hp/tq. I don't drive hard at all, but im thinking maybe my clutch was slipping
My buddy with a GTI said that GTI's have this problem when they upgrade their chips. He said its called boost surging and they fix this problem by replacing their N75 Valve. Do we have a valve similar to this? Could this be my problem too?
Any help is welcomed
NEW PROBLEM
So I thought my troubles were behind me but I guess not.
My car runs fine until I hit boost, and once I hit boost i Get code p0102 (MAF circuit low input) and the Throttle no longer works. My scanguage is hooked up and the Throttle position sensor reads perfectly fine. With the CEL on, I will go WOT and the TPS % increases but my car doesn't go anywhere, not until I downshift then the car will sputter along. Once I clear the code the car runs perfect, that is until I go into boost then it happens all over again.
I had an appointment this moring with my tuner, but wasnt able to make it because my car was running like ____. I also hear a click everytime i push the throttle
My question is, is my problem my MAF? I dont think its my throttle position sensor, since we have electronic throttles so i assume that the MAF code will affect my Throttle response.
I already cleaned the MAF with cleaner and reset the battery and it still does the same stuff. I just dont feel like spending $150 on a new MAF and it do nothing for me
Anyone have any clue?
Old May 27, 2008 | 05:17 AM
Angry_Celi_Guy's Avatar
when you stopped was the engine revving or did it drop off also?
Old May 27, 2008 | 05:39 AM
draxcaliber's Avatar
clutch slippage means that your rpms go up while your speed doesn't while in gear and the clutch is engaged. so if that happened, you would have bounced off the rev limitor. or maybe that is what happened, you bounced off the rev limitor.
but as for valve, what kind of valve is an n75? you have valves on your car, but what does that one regulate?
Old May 27, 2008 | 07:40 AM
NVMyTc's Avatar
I know for sure I didn't bounce off the limiter, My RPM's dropped as if my foot was off the gas yet my foot was floored.
My buddy said that the N75 valve controls the wastegate, but the GTI's have internal wastegates so I believe that this wont apply to me.
Thanks for the help so far. If anyone else can figure out what went wrong I would love some help. I'm not so ____ed that it happen as much as I lost the race, I was pulling on that sucker too! lol
Old May 27, 2008 | 09:53 AM
athletefeet66's Avatar
fuel cut? maybe you need to upgrade to bigger injectors? just a suggestion...thats what it sounds like
Old May 27, 2008 | 11:44 AM
aen's Avatar
aen
sounds like tuning problem, maybe something changed that needs to be worked on
did you see your afr's when that happened? go try to replicate and report back with AFR and all that jazz.
also, if you can't replicate it then you are probably fine. if you can THEN we might have a problem
Old May 27, 2008 | 01:35 PM
SoFloTC's Avatar
i have a similiar problem.. i hit the gas and my AFR goes so high on the aem the it makes 3 dashes, and my boost spiked to 7 and all i hear is lots of backfire like pop pop pop but im not going anywhere..
Old May 27, 2008 | 01:38 PM
B_Real45's Avatar
Maybe it's a throttle signal issue.. like for whatever reason the computer saw your throttle as closed - then picked back up the signal and opened throttle again.
Old May 27, 2008 | 05:21 PM
NVMyTc's Avatar
Im running 550's so I think im ok
I just got retuned about 4 days ago, If i remember correctly my A/F was ---
Sounds similar to me, do you still have this problem? Did you find a solution?
I was reading up on that too. Some people were throwing code P2111 and having the same issues as me, but my car didn't throw a code
Thanks for everyones help, Ill try to launch from a stop again and report back
Old May 27, 2008 | 05:22 PM
aen's Avatar
aen
--- = really high AFR.
translates to boost leak
go check all plumbing
Old May 27, 2008 | 05:39 PM
NVMyTc's Avatar
As far as All my Vac lines and intercooler piping right?
Old May 27, 2008 | 05:45 PM
SoFloTC's Avatar
oo i must have a leak then
but then again its not happening all the time? it will happen and then ill turn it off and let it sit for like a couple hours go for a ride again and it might or might not happen
Old May 27, 2008 | 06:10 PM
aen's Avatar
aen
sometimes couplers have a chance to settle then kinda flap away as you drive...or, depending on how much pressure...that's whats required to break the seal that the couplers make
check all lines/ic piping
Old May 27, 2008 | 06:22 PM
B_Real45's Avatar
MVMyTc and SoFloTC - you guys also need to make sure to fix any exhaust leaks before turbo - this could cause high AFR and slow spool.
Old May 27, 2008 | 09:37 PM
canadian48205's Avatar
Def sounds like a boost leak to me!!
Old May 27, 2008 | 10:40 PM
NVMyTc's Avatar
I re-did my entire Vac Line setup and double checked all my couplers. Everything seemed to be fine
I took it out for a run and did a pull from a stop and it ran perfect,
Maybe it was a one time fluke?
Old May 28, 2008 | 12:12 AM
aen's Avatar
aen
maybe because you checked it you pushed something in lol. sometimes small boost leak = big problem
Old May 28, 2008 | 12:55 AM
java09's Avatar
^^agreed.
Old May 28, 2008 | 05:55 PM
Keep checkin all the ic piping often for the next couple of weeks or even better yet to a boost leak test!!!!!
Old May 28, 2008 | 08:03 PM
Ace83's Avatar
Ronin Scion
if not leaks then tuning issue then.. -- is too lean
