Weird Idle issues on a Hot Start up
im boosted and fully tuned on a aem fic.....recently,on hot start ups....my idle will become lil bouncy for like a good min or two but never stalls....while this hapens,the afrs,go from 14.5 to really lean and back and fourth,after a min or two the idle reajust and everything goes back to normal as well as the afrs......recently the weather over here on the North east,been warm to ice cold and so fourth,but im thinking its something else,like maybe a dirty maf sensor,or maybe a vacuum leak,its really been too cold to check over the car,but any input would be great
Ah, so this is happening right after a tune? Well no doubt its the tune brother. And yes, alternator can cause this sort of idle if the car keeps wanting to die. It'll lower and then bounce back up, hold, lower, bouce back up, hold... yada yada.
no not after the tune...i say about 4-5 months afterwards...starting to experience weird idle issues on hot start up...from 1st gear into neutral....the idle would boucne a lil bit to a point where the car would just die,but after a few min of driving it would be fine.....but now...on hot startups..idle bounces up and down from like 1100 rpm to like 500 rpm back and fourth give ir take...tryes to settles down after a few secs but continues for like a good min or two..but returns to normal.........ask a few of my buddies..they said the alternator would cause such a issue....if it wasnt happening directly after the tune..i noticed when i have my head lights on,i get kind of harsh idle issues coming to a stop from like neutral....which wasnt to harsh when lights were off,which lead me to beleive to be a eletrical issue
Eh. I've seen worse. I was hoping you'd say mid 11's because then I could tell you for sure, but 12's aren't telling me too much, that's not too bad. I guess, what is your battery sitting at? Dead batteries can do this as well, but usually not like you described, but at least it's a shot.
i have a optimum red top..lil over 3 yrs old....i mean i know the optimal volts are 13.6-14.....but i dont have a new batt...so not expecting that...but my battery may be getting weak....when my fans kick on...the lowest i seen is 12 volts...give or take...my idle is 13.1-13.3.....right around there...driving pretty much at that point...doesnt lower....i guess if my alternator was going it wouldnt properly charge my battery.....
interesting...your prob right..my first red top.....ive herd mixed reviews on these batteries,some say there life is short others say,there long,so should i get a stock battery or is there anything out there,thats better then stock esp on cold starts....
It's the heat. I have the same issue. I drove it all during winter and it never died once. it starts warming up come spring time it dies like crazy. Just change your exhaust manifold to something like this and heat wrap the crap out of it. Also get a cut out hood like evo 8/9's do.
Bakoscion46x
01-19-2015 02:39 AM
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
