2007 HVAC Lighting Issue Fix
Old Apr 12, 2012 | 04:09 AM
  #61
tapply4894's Avatar
Yeah mine does the same thing with the head lights.
Old Apr 25, 2012 | 02:48 AM
  #62
engifineer's Avatar
Originally Posted by usafscion
Huh.... this is nuts... I have the same problem. 07 TC and I don't remember if this all happened when I changed my stock radio for a pioneer... but I can see that the lightning off of the clock works but I soon as I turn the headlights on, the lighting on the clock goes out. ( and no other lighting on the HVAC ) (all functions still works)
any one knows what this could be?
That is the common 07 hvac issue that this thread is about Unless you messed up something in the dimmer wiring then I would guess that you should check for this issue on the board.
Old Jul 27, 2012 | 10:29 PM
  #63
SilentSeraph's Avatar
Alright, so I took it all apart, fount T303 and T304, both seemed to be connected fine. Neither would budge with minor applied force. Took a magnifying glass to take a closer look and they are connected. Im having the same issues with everyone else, 07 TC w/aftermarket pioneer deck, the HVAC lights turn off when headlights turn on. I notice when I apply force near the "off" for the air conditioner the HVAC lights up and will sometimes say on. Does anyone have any other suggestion?
Old Jan 2, 2013 | 11:14 PM
  #64
johnnyr888's Avatar
Default Thank you, thank you, thank you...
Thanks for simple instructions and relatively easy fix!
Old Jan 11, 2013 | 09:02 PM
  #65
ScionOfLife's Avatar
Default Old problem - new Twist? T302 HVAC Lighting OUT
So my just purchased 2007 tC, which I researched so carefully has the HVAC Lighting issue. I even spent time reviewing forums for issue, but failed to spot this (Didn't know to search for it till I had the car/issue!
So ALL the lights on the buttons are out on the HVAC face, and only the LCD display lights/goes out with headlights or parking lights on. I have not seen this particular flavor of the issue before, most have all the lights on or all off. The only lights I ever see are on the HVAC LCD display. The buttons never light. The fact that the display light it toggles on/off with headlights looks like classic t302 solder points, but why then al the button lights out, do I have additional issues to deal with? Does anyone have a spare circuit board so that when I pull it apart, if it's more than just the t302, I would not have to do this twice? I could pay a bit for the board if I need it. Ugh. this is really putting a damper on the new ownership experience, especially since the LED Third/High Brake Light strip is also dead - got the dealer willing to replace that if needed anyway.
As I reread the thread - my symptoms very closely match this:
Old Jan 11, 2013 | 09:57 PM
  #66
LEDmod's Avatar
Just do the solder properly and you shouldn't have issues with them...
For the TBL, just buy aftermarket TBL with full extended LED
If you just bougte the car recently dealer should replace that for you.. since that light is required light to be functional to be on the road...
Old Jan 12, 2013 | 05:34 PM
  #67
Default Thanks
Yeah, I got all the way to my second day of ownership before getting hit with 3, count' em 3 known or common issues. The dealer is gonna have to take the hit on the TBL, since he gave it a passing inspection. Don't think he wants the DOT coming around wondering why he is passing cars with lights that don;t work, LOL!
So, TBL, HVAC lights, and here's a biggie: No master keys. None, just a Valet key... this sucks. I got a dealer here in Raleigh that will reseed either the ECU or immobilizer (can only be done a single time, but my odds are good as this was a single owner car) and he will code it to a new master and include the Valet in the coding for $90. Not too terrible, now if I can just find a master blank for a decent price. eBay had an OEM one for $175, and aftermarkets for $42. Do I trust the non-OEM ones, or what?
Old Dec 19, 2013 | 02:06 AM
  #68
mc1114's Avatar
Originally Posted by Lntodd2
I seem to be having the same problems as the 2007 but my car is a 2005. I have taken apart the hvac and looked for the resistor t302 however had no luck. The 2005-2006 hvac motherboards are different from the 2007.
Originally Posted by engifineer
They changed the board layout in 2007, so they will indeed be different.
Has anything at all been done to the car? LED swap, replacing the HVAC (replacing an 05-06 unit with an 07+ will cause issues for example).
Make sure that when you get replacement unit. Get the year from 05 - 06
07 and up model does not work on 05-06 tC
New 07 TC owner here, having the same issue. Tried to do the solder trick but did not work
From everything stated above, it seems 05-06 units are not compatible with 07, which might explain why, when I swapped units with an 06 (good working unit), neither car had working HVAC controls, although the physical connection at the back was the same
However, Scion OEM parts sites list the same part number for 05-07 (55911-21020), and on Ebay the listings are for used units that will fit 05-07
Anyone have some insight? I'd really like to get this fixed with a used unit. For a lack of a better term, it sucks being unable to see the controls at night. lol
Old Dec 21, 2013 | 02:18 AM
  #69
mc1114's Avatar
So 08 will work with 07 but 05-06 will not. Found a used unit from a 08, without being sure if it was compatible. Turns out it is. Only thing is the colors at night are slightly different compared to the gauges and radio, but thats just minor. So glad to have this fixed finally
Old Jul 17, 2017 | 02:16 AM
  #70
kfox112's Avatar
Good evening,
I recently purchased a 2007 Scion TC to learn how to drive a manual transmission. I do love it so far. I noticed though that when I turn on my headlights, my clock backlight turns off - ergo why I found this thread.
I attempted the fix in the original post with much difficulty since my soldering iron tip is not nearly as small as this tiny T302 transistor. To my amazement, it worked when I tested with just the board. On go the headlights, the clock stayed lit, and an array of new LEDs that I'd never seen before (presumably to keep buttons illuminated at night) kicked on too. I was so happy... at least until I put everything back together and it stopped working again.
Taking the screws back out didn't fix the issue, so I retried the solder reflow fix with success two more times, and had the same problem both times - re-installing the screws that hold the circuit board to the plastic back put me back at square one.
On my fourth attempt, I ended up breaking the transistor off of the board. And now - it only has two legs instead of three. The leg on the single side is broken off. Even though I'm transistorless, everything works exactly as it had before - no backlight when the headlights are on, but the clock illuminates when the headlights are off.
So I'm left wondering - do I have any options at this point other than buying a new board? Is a transistor "done" once a leg falls off... or with the right size (tiny) soldering iron, could you potentially solder a leg back on?
Thanks for the help,
-Kyle
xBSciontist
Jun 18, 2019 03:06 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
VCUBoy714
Jan 5, 2015 08:46 PM
