Amp left on?
Old Jan 24, 2007 | 03:10 AM
htowntc's Avatar
Default Amp left on?
Ok, hooked my amp and stuff up today.. in the rain.. anyhoo
first off if i take my remote wire and just connect that to the 12v power slot and just tie them together will it hurt the car? i mean i know the amp will be on 24/7 but how much power could it actaully use?
and would it just be easier to get a little switch and use one of them empty slots were the foglight switch would go i think, an furthormore, id just find a fuse that had constant power like the acc fuse but i can't sem to figure out how to open the fuse box.. could someone elxplaine that to me,
and no i don't have an aftermarket radio so i can't just use the little blue remote wire that is all purdy with the unit,
Old Jan 24, 2007 | 03:22 AM
StealthScion's Avatar
tap into the hu's power wire, so the amp only comes on when the hu is on.
otherwise you'll drain your battery
Old Jan 24, 2007 | 03:24 AM
htowntc's Avatar
Default stock
my hu is stock, so what if i just used the radio fuse, and pushed my little hapy wire in their, were is the fuse box at under the knees of the driver side?
Old Jan 24, 2007 | 03:26 AM
Tcguy85's Avatar
there is a wire you can hook to behind the deck that will only be on when the ignition is on.
Old Jan 24, 2007 | 03:28 AM
htowntc's Avatar
Default factory?
the factory radio has that wire too? ooo i see, well it would be much easier if i just used the fuse box because i don't wana spend all that time lookin for the wire, expecially with it being japanese, i duno what color it would be, so back to that fuse box were is it
Old Jan 24, 2007 | 04:18 AM
mattieg's Avatar
The fuse box and the wire behind the radio with be the exact same thing. Your tapping into the ignition wire where it will only send 12 volts when the key is in the on position.
Old Jan 24, 2007 | 04:23 AM
htowntc's Avatar
Default ah
i know their the same thing.. but what's easier messin around and getting behind the radio or just plugginit into a fuse spot
Old Jan 24, 2007 | 01:26 PM
Zebman's Avatar
Getting behind the radio. Assuming you've never taken off the center console, it only takes 30 seconds, a deep-well 10mm socket and a phillips screwdriver. The fuses are in the engine bay, i'm pretty sure. Pushing a 12-18awg wire through the firewall grommet is going to be MUCH more painful.
Mind you there are other places to plug it in, but I would take the time to use the blue wire on the harness for the radio.
Old Jan 24, 2007 | 01:56 PM
teamben158's Avatar
I think he is talking about the fuses underneath the dash, not in the engine bay.
Old Jan 24, 2007 | 03:11 PM
htowntc's Avatar
Default no
yes i was talkin about the under dash fuses but it's ok because i just connected the remote to the 12volt and installed an inline switch on one of those open spots for switches works great now
Old Jan 24, 2007 | 06:50 PM
nodsetse's Avatar
^Your solution will work fine long-term, provided you don't mind having to flip the switch. You could have a problem if you forget to turn it off and leave the car parked for a long time, as it could drain the battery. No idea what amp(s) you have, but some can draw 1 to 2 amps at idle, which would eventually result in a dead battery.
Old Jan 25, 2007 | 12:04 AM
Scionizer07's Avatar
Some people make life way more difficult then it has to be... Tap into the grey wire behind the deck and it will turn the amp on and off with the ignition. End of story.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Sep 8, 2015 02:58 PM
