avic d2 question
i just hooked up a dvd player to it and it does not work when the car is moving does any one know a way to by pass this. i alredy have the parking brake wire that is green hooked up to the ground. on nost indash dvd players if u hook the grenn wire to a ground the dvd will work as you drive. does any know how to by pass the avic d2
uhh google avic...there is a site that tells you how to do it i forgot how to do it.
u take off the sleeve (metal frame) n theres a lil switch jus turn it to the other way it should work
ur gona have to take the d2 back out. there is 4 screw holding the metal frame, once u open that there is a little switch, turn that switch to the other side it should work
the metal frame is used to lock the unit so ppl cant try to steal it take that piece off to turn the switch n put it back on |
and understand that this will void your warranty.
thanks for the help i jused by passed it. all i had to do was add a wire next to the ground wire and just ground it
also has anyone hooked up the speed sensor wire
