DIY: Make your tC Chirp/Honk (factory) when locks are pressed
Old 08-05-2013, 04:35 PM
  #81
DigitalPro's Avatar
Sounds good.
I have a 2009, did you happen to note the color of the wires you tapped into? Also did you run the wire w/diode into the horn relay in the under hood fuse box? Since you used the door lock motor wiring when you hit the door locks inside the car while driving do your siren chirp?
DigitalPro is offline
Old 08-05-2013, 07:50 PM
  #82
Vladislav's Avatar
Originally Posted by DigitalPro
Sounds good.
I used the pink wire for the red wire and the blue for the black.
I made a DIY for it here as our cars are different than the 04-06 models. https://www.scionlife.com/forums/showthread.php?p=4062960
I did not wire it to the horn but used a siren from my wife's old car alarm. Yes it still makes the chirp when you press the lock buttons inside the car.
Vladislav is offline
Old 08-10-2013, 08:28 PM
  #83
tCjosh's Avatar
i cant find that 50v 6amp diode at any of my radioshacks.. i find a 50v 1amp diode, would that work fine?
tCjosh is offline
Old 08-10-2013, 08:30 PM
  #84
DigitalPro's Avatar
That will work just fine.
Old 06-18-2019, 11:27 AM
  #85
Administrator
Administrator
MR_LUV's Avatar
Thumbs up
MR_LUV is offline
Fhe1079
12-01-2018 06:27 AM
EExA
33
08-31-2015 08:24 PM
diablo243
19
04-12-2008 07:48 PM
Spect2K3
Scion tC 1G ICE & Interior
61
04-15-2007 08:18 PM
Max2k
46
11-18-2004 04:11 AM
Quick Reply: DIY: Make your tC Chirp/Honk (factory) when locks are pressed
