DIY: Upgrade the bazooka sub and Amp (tons of Pix!)
Old May 25, 2006 | 10:03 PM
xtonyC's Avatar
Waitttt....did you use the existing wiring from the HU to the amp? If that's the case, I may be doing this soon. I didn't want to rewire my whole car.
Old May 26, 2006 | 04:07 AM
mr_lore's Avatar
yep!
Old May 26, 2006 | 05:48 AM
theSciontologist's Avatar
Originally Posted by mr_lore
I didnt try but from the looks of it I think that would be a negative...Why would you want to cover up a nice looking sub anyways?
haha i wouldnt! just that little hole bothers me and i think it should be meshed or something... hahaha but it looks great!
just hope i can do it soon
Old May 26, 2006 | 06:12 PM
JasonH's Avatar
Nice work!
Old May 26, 2006 | 08:47 PM
xtonyC's Avatar
yep!
Anyway you could do a write-up of the instructions to go along with the pictures. I understand what's going in most of em...but some I'm not sure.
Old May 27, 2006 | 04:25 AM
mr_lore's Avatar
yep!
Pictures speak a thousand words....this was more of a 'see it does fit' guide, the electronics will vary from application to application so if your lost on that part you should do some reading up.
Old May 28, 2006 | 02:32 AM
xtonyC's Avatar
What we need, is someway to plug that port really well. THEN, something that covers up everything EXCEPT the sub itself. So the non-functioning gain ****, the plugged port, and the lip of the enclosure will be closed up to make it look flush.
HMMMM, I just might have to do some good ol' homemade customizing to that cover [and deffinately get rid of the Bazooka emblem they got on there].
Old May 28, 2006 | 03:57 PM
mr_lore's Avatar
Yep, I've been tossing around the idea of 1/2inch mirror plexi with generous ammounts of epoxy behind it and a wood screw every so often....
Old May 30, 2006 | 11:17 AM
SCI_TC_GUY's Avatar
this looks like the BEST solution for sealing up the stock enclosure...
https://www.scionlife.com/forums/viewtopic.php?t=118370
excellent!!
Old May 30, 2006 | 02:13 PM
mr_lore's Avatar
Good find, it looks hideous but sound quality wise its probably the best thing since sliced bread.
I see a trip to ACE in my future...
Old May 30, 2006 | 02:25 PM
SCI_TC_GUY's Avatar
I'd have to agree... for SQ this is probably the best solution
Old May 31, 2006 | 02:02 AM
xtonyC's Avatar
Yeah, I actually intended doing that weeks ago and just got around to it right after posting that. It fits really well. mr_lore, you should be able to still seal it with the Type-S sub. But if anyone goes to Type-R, based on my calculations of airspace, the port will need to be OPENED. For other subs, refer to this thread about airspace:
https://www.scionlife.com/forums/viewtopic.php?t=122126
and then check the specs for your subwoofer whether it needs to be ported or not. I haven't noticed any subs that would not work based on airspace, but some highend subs, like Type-X's may not..not sure.
mr_lore, if you want to maybe work together on getting a design for a cover...PM or AIM me at ttttonyTM
Old Jul 17, 2006 | 06:22 PM
Bluechualappa's Avatar
So I don't know much about subs but I am thinking about doing this and have some questions.
1)If you upgrade the sub and amp can you still control the bass from the Headunit?
2)Is the box big enough to support the increase in power from a new sub and amp. Will it sound good or will it sound like a crappy box?
I was thinking about a 10" pioneer sub that is 600w max for $70 brand new.
I need to find a cheap amp that can support this...
Old Jul 19, 2006 | 11:31 PM
When I upgrade mine tomorrow(hopefully) I will post a vid of the new result? I already disassembled it and forgot to do one from before...
Like the author of this thread, I think his intentions were slightly more power and bang. Not a full fledged system for shows! That's what I want atleast cause the stock is pretty weak.
I plan on:
Polk Momo 10" DVC sub
and my 850max watt amp will be placed underneath the carpet.
Anyone think I should seal the box?
I need the run down on wire plz...
Stock bazooka wire harness-
Blue-headunit control?
Red-power which i will not use( using the new wiring from my power acustic wires to battery?)
Ground is black?
All I need connected to the amp is the power, positive and ground? Then hook up the wire harness to the amp and run the sub wires to the sub?
Old Jul 20, 2006 | 01:15 PM
Kratos's Avatar
are those 3 terminals on the right right side of your amp your power, remote turn on, and ground wires? I see a red and a blue wire can't see the color of the third ... if so the gauge used looks silly small ... the gauge of the speaker wire used looks bigger than the power wire ...
Old Jul 21, 2006 | 04:38 AM
I need help guys...
My friends and I did this today with my new polk momo 10" and pioneer gm-510t, its a 2 channel amp i know but it said when bridged it would power 1 sub at 380w, just above the reccomended 300w mark but far from max 600w.
Well at low volume on my head unit the sub is alright, doesnt hit as hard as the bazooka and will miss random bass hits in the music. When I turn the volume up the sub shuts off all together and when I bring the volume back down it will turn back on but not be very loud.
What do you think is wrong? I have the gain set at normal but i tried to up it and it hit hard at low volume but i made bad sounds at high volume so i shut off fast and set it back to normal. I have the bass boost on medium setting but thats not the problem i think. And theres a little switch for LFS where u set it to power a speaker or a sub so its on sub cause when it was on speaker it played music from the sub lol!
Anyways I think we have it bridged right now but why does it sound like this? Mayde unbrdge it? then its only 125w??? Help plzzz
Old Jul 21, 2006 | 04:04 PM
mr_lore's Avatar
sounds like the frequency is too high or your x-over is messed up, you should have 3 tweakable settings on your amp, tweak all 3 and search for a guide to do so.
Old Jul 21, 2006 | 06:43 PM
fastandcurious's Avatar
yep!
wait, are you using the cables from the bazooka harness to power your amp? like Kratos mentioned, the gauge of the speaker cable looks bigger than the gauge of the power cable so i can only assume that's what you did.
also, you have the stock headunit, correct?
Old Jul 21, 2006 | 06:56 PM
mr_lore's Avatar
yep!
good call! Definetly do not want to power your amp off of the old amp...
Old Jul 21, 2006 | 07:02 PM
*scratching head* could your answers be any more vague? lol
also, i missed where you mentioned you have an alpine 9853 headunit.
