Door locks/triggers for alarm. Help!
Hey guys. New to this forum but I love it. I bought a Viper alarm (Model 3400) about 2 months ago. For me 05 Scion tC and I've been researching this whole time and finally felt comfortable to install it on my tC1. I hooked up all the necessary wires. Well best to my ability. I wasn't able to find the passenger door trigger. So long story short I installed it. And it arms and disarms fine. It goes off when I open the driver door. But the lock and unlock doesn't work from the Viper remote. And from what I can tell I don't need relays? I'm Confused on the wiring because it says for the lock it's -green to blue and unlock -purple to pink What does that mean?? Lock in and lock going out maybe? Do I need to tap into both wires? Also I couldn't get the parking lights to work or trunk pin switch. Any help would be greatly appreciated! Thanks *Moved to Correct Forum by Moderator |
so I figured mostly everything else out except for a issue with my hoodpin and the passenger door trigger. But everything else is all good. The wires that I found online for the LOCK and UNLOCK were not the ones I used for the alarm. I tried it and they didn't work. I avtually ended up using the red wire in the same plug. And I believe the the green for unlock. Just am update if anyone is having the same issue or planning on attempting this |
