Guage and center console lights don't work...
Last night wheen I turned on my car and turned the lights on I noticed none of my guage lights work and the odometer light was off, but my gear light was on ( P, R, N, D, etc...). Also I have a CEL on to and that was still on. Also my center console lights weren't on except for the button that was pressed. I also noticed when I turn my lights off the backlight to the odometer and the clock turn on. I checked the fuses and everything seems ok. I haven't done anything electrical to the car (new headunit) in over a year so I don't know what suddenly happened. Any ideas?
Thanks,
Stoked
Thanks,
Stoked
I just had a circuit board in mine replaced for this problem...is yours a 2007? It's a common problem with that year.
Did you check the fuses under the dash? I know that's what it was on mine. It just about drove me crazy. I didn't know about those fuses. lol
^^ yeah.. turn up your dimmer switch man.
No, I installed my headunit over a year ago. Where is the dimmer? I didn't know there was a dimmer...
Maybe the leftmost gauge? I forget, I'll have to look later. It should be pretty easy to find...
the dimmer switch is on the actual gauge face itself, should be right next to the one where u can check ur trip mileage
it should be the **** right below the temperature gauge. Turn that to adjust the level of lighting of your display.
Fixed the problem... It was the dimmer. I took my car to a different place (Firestone) to change my oil Monday I guess they turned the **** trying to figure out how to turn off the maintenance light. Thanks for the help!
Stoked
Stoked
ExtremeDimensions
12-18-2014 04:47 PM
