HDD in check mode
Old Jul 8, 2006 | 10:38 PM
PlayinWithFire's Avatar
Default HDD in check mode
I got the AVN-7000 HU and the radio works fine but when i try to access navigation the thing says "HDD in check mode". Anybody know of a way to solve this?
Old Jul 8, 2006 | 10:46 PM
jwaggz82's Avatar
Sounds like a hard drive thing.
Old Jul 9, 2006 | 12:35 AM
iowagary's Avatar
Right - sounds like a hard drive error - it sounds like the drive is detecting disc integrity problems and is trying to fix them... if I'm right, usually drives that are having those sort of problems are not long for this world - if it's under warranty, it's time to take it in.
Old Jul 9, 2006 | 03:11 AM
jwaggz82's Avatar
inside the unit is this a normal computer hard drive? if so its pretty easy to run some disk checks on it if its not under warranty.
Old Jul 9, 2006 | 05:23 AM
iowagary's Avatar
right, but that would mean taking it out of the unit and putting it in a computer. I don't know this for a fact, but I think it's most probable that it is a regular laptop harddrive - 2.5". Which would mean you'd need to get a 2.5 - 3.5 adaptor before you could do it in a desktop pc.
Old Jul 9, 2006 | 05:43 AM
etsnet's Avatar
Can you get into the system check screen under the info screen? If so are you getting any readings?
Is this a new system or old? Did you just install it and if so did you install it yourself?
Old Jul 9, 2006 | 04:52 PM
my local shop installed it. I can only access the radio and my RCAs (sirius is plugged in). Do you think if i just disconected my battery and reconnected it it would reset it and it would work?
Old Jul 9, 2006 | 05:04 PM
jwaggz82's Avatar
I think you should go back to the shop and have them double check things. Since you paid someone to install I think they should try to troubleshoot it first. Sorry but I dont have such a nice radio (hehe) ...j/k ... but really - I would tell them it never worked. OR - call the manufacturer and have them tell you what that means. Once you know the problem its easier to know how to fix it.
Old Jul 9, 2006 | 05:19 PM
etsnet's Avatar
^^^ditto
Old Jul 9, 2006 | 06:28 PM
the guys who installed it semi sponsor my vehicle. I have shown with them at many shows so they know it worked and were there when the first message popped up. They installed it even tho they dont work with eclipse units and the guy at crutchfield had no idea what the heck it goin into check mode was (no troubleshoot for that in the manual). I believe since it is basically a harddrive like a computer maybe some file is corrupted and it needs to be checked. The wierd thing is this happened last weekend and i hit a bunch of buttons (the solution to any problem) and it worked. But now i dont know how i did that... maybe i reset the HDD but I was just looking to see if anyone else has had an issue with their nav on their eclipse units. I will just contact eclipse tomorrow but i wanted to see if anyone on here had an answer.
Old Jul 9, 2006 | 10:53 PM
iowagary's Avatar
I doubt it's one corrupted file - It might have been a corrupted file but it sounds like a hardware error, which will keep happening. I'd call Eclipse.
Old Jul 10, 2006 | 02:57 AM
i mean a corrupted internal file... cause maybe it works like a computer and the drive might have a "boot" file... i dunno...
Old Jul 10, 2006 | 03:48 AM
iowagary's Avatar
hypothetically possible... but disc checks just don't often come from one corrupted file.
Old Jul 10, 2006 | 06:12 AM
etsnet's Avatar
Well it could be a couple of bad sectors with boot files on them. Once that happens forget about it, the hard drive is never the same.
Old Jul 12, 2006 | 01:50 AM
so i tried to reset it by takin of the negative battery terminal... and it never came back on. The screen lit up and the buttons did to but nothing showed up. The thing is totally fried and im just sending it back to eclipse. Thanks for your help guys.
BTW the guy at eclipse had never heard of the HUs goin into "check mode" so i guess im a first
Old Jul 12, 2006 | 03:02 AM
paul34's Avatar
the HD probably failed... although I'm sure its well protected its still a hard drive in a moving, climate variable environment like a car, so not surprising
good thing you're getting it replaced
archangel
Apr 12, 2015 01:33 AM
mischman
Mar 31, 2015 03:16 AM
Inazuma
30
Jan 23, 2004 04:50 PM
George
14
Jan 17, 2004 04:08 AM
Docsnuff
Jan 12, 2004 11:18 PM
