Help airbag light on! How to remove it?!?
Old 04-18-2019, 08:46 PM
1slowsciontc's Avatar
Default Help airbag light on! How to remove it?!?
So I replaced my clock spring and my airbag light went on.
I want to know what I did wrong or how to fix the problem?
Any suggestion?
______________________________
Last edited by MR_LUV; 04-19-2019 at 12:24 PM. Reason: Moved to Correct Forum by Administrator
1slowsciontc is offline
Old 04-19-2019, 03:54 AM
dogg's Avatar
a little more info would be nice...what is the clock spring you talk about??? as far as i know, there is no mechanical clock in the vehicle that would have a clock spring...
if you are talking about the steering wheel...did you follow the maintenance manual for removal and reinstall of it, which would, im sure, instruct you what to do to the airbag system to prevent what you are saying...
if not, i cant help you...
dogg is offline
Old 04-19-2019, 08:59 AM
This is a clock spring bro
Old 04-20-2019, 06:50 PM
62Fender's Avatar
Assuming your connections were double checked and fully seated (with no bent connector pins) you might need a reset.
Reset blinking SRS light:
62Fender is offline
Old 04-20-2019, 10:51 PM
dogg's Avatar
Kewl...never would have known, thanks...you know its upside down, right??? maybe the prob???
hahaha, Just jerkin your chain....hope you work it out before you might need the bags to save you...
let us know what you find...may help someone in the future...
dogg is offline
tmo
06-27-2019 04:46 AM
johnnymejia7
Scion tC 1G ICE & Interior
03-04-2019 05:56 PM
ozyborne
01-04-2018 02:32 PM
ozyborne
04-27-2017 06:16 PM
Sickrickl
03-03-2014 02:25 AM
Quick Reply: Help airbag light on! How to remove it?!?
