Help!!! window switch not working
can't control my pass window on the master switch from the driver side but i could roll down pass side window on the pass side, already try to reset it does not work
do you have the lock on?
did u try to remove the neg bat and do a full reset?
im sure you reset the ecu and didnt reset the windows
any time you disconnect your battery you must reset the windows and sunroof for your windows fully close the window first fully depress the window switch to roll down all the way fully pull the switch to roll up all the way and your done do the same exact thing to your passenger window using the passenger window switch and same for your sunroof |
