Interior UV Black Light LED for dome light
Has anyone used any of the UV Black light LEDs for the front dome Light? I found three on the superbrightleds.com
1. T13 Wedge Base LED bulb UV-BlackLight
2. WLED 4-LED bulb UV-BlackLight
3. WLED 1-LED bulb Wide viewing angle UV-BlackLight
Also i was wondering, if the first on listed would fit in the front dome light and if it was any brighter than the second one or if the third one listed actually covered the car better due its wide viewing angle but is one LED too dim to have any effect?
What i am thinking of doing is replacing all three front dome lights with:
drivers side map light - to a UV black light (can turn this on while driving to make everything white glow)
Center light - to a Blue LED (this on with the UV should be interesting)
Passenger side - to a super white LED
That way i got everything covered!!!
Your help is greatly appreciated!
Thanks,
Thanks,
I bought a UV light for the rear dome light and I didnt like it. I could barely tell it was on it was so dim. It was the 4 LED fetsoon (or however its spelled) bulb from SuperBrightLEDs.com. I now have it in blue which is amazingly bright!
I also did the front center light in blue which is really bright. My driver and passanger side are green but they were white. the white works really well.
All my dome lights are BLue but its too much blue for me, originally i had bought two white ones for the map lights and 2 blue one for my licence plate lights,,,but then i found out its illegal for blue exterior lights, so i put the white ones for the license plate and the blue ones inside.
When you had the UV light on, did anything white even glow under the light?
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
XB06
May 30, 2015 02:42 AM
umnitza
Dec 1, 2014 06:26 PM
