karr alarm system
i want an alarm but i dont want the scion alarm. i have heard of some ppl gettin the dealer karr alarm. is it anygood? does it use the factory key w/o a seperate transmitter? and what is the price of the alarm? thanks
I have the Karr alarm. The dealer installed it the day I got my car. I didnt realize until about a month ago that it wasnt the scion alarm. A nice feature is that it beeps your horn when you lock and unlock you doors. It works with the factory keys. I would say that I havent had any issue with it.
same here.. i got the karr alarm in my car.. the only thing is the super bright wide angle LED that blinks in my car..
it's KARR
I'm not sure how much it was. I just had it added with all the other charges for the car. You may want to look into one of those alarms that will page you if your alarm goes off.
i had the karr alarm as an option at the dealership thinking that that was the stock factory alarm. *shrugs* i can kick my car and it wont go off.. and i have it on the highest sensitivity.. i think imma relocate the blue box when i get the chance.
^^^ my buddies were being dumb and kept hitting my car until the alarm went off... haha.. it went off 8 out of 10 times they hit it.. but they gave it a good thump...
I have it. My sensitivity is set at about halfway and it goes off when i close my hood. It's not like i drop it from way high either.
If you're coming to SD and still need it let me know. I know someone who can do it for about $130. You can disable the honking (when you un/lock if you want). And you can have it arm itself 30 secs after your dome lights go out (good feature if you forget to hit the button often) and this can be disabled too. |
Jose06tC, How do you get it to arm itself 30 secs after you dome lights go out? :ponder:
there should be an entire booklet for the karr system that tells you how to turn on/off/adjust every feature.
i think you should get the VIP REMOTE START and then let me know if it works for the tC. :P
get the ones made for the camry and get the key to test out the trunk release too |
hmm... just to add.... remote start for manuals are a bad idea...
you never know what'll happen... trust me.. i've seen plenty of accidents... including one of a nice tC that it's owner never thought would happen.. and it did. it wasn't worth it in the end. all it takes is one accident. |
you never know what'll happen... trust me.. i've seen plenty of accidents... including one of a nice tC that it's owner never thought would happen.. and it did. it wasn't worth it in the end. all it takes is one accident. my alrm has a remote start feature and was built specifically for manual transmissions. I only go with the best. I went with AutoPage Here's how it works. If I want to enable remote start, I press a key on my LCD remote, then do what I have to do close the door, lock it on the LCD remote and the car arms itslef as well as shuts off. When I'm ready to turn it on again, I press one key on the remote - very simple and very easy |
^^ seems that way it makes sure that your car isn't in gear when you shut down the car.
in that case, :) |
in that case, :) |
oh and btw the trunk releases with the push of a button as well. Also I can check indoor and outdoor tmp and set the car to start at a time I want automatically. or i can have the ac turn on when it gets to hot outside or vice versa with the heat/cold weather
Okay Don, HOW MUCH?!
