Need Assistance... installed HID, now have electrical probs.
Today I installed the Operatic HID kit. Pretty self explanatory. Worked fine but now the "auto roll down" feature on my power windows don't work. I also can't roll the passenger window down from the driver side. I checked the fuses inside the car, then ended up checking every single one. All fine. Checked fuses in engine bay, all fine. Disconnected all power sources to the HID kit, same result, no auto roll down. I also notice that the car sometimes dips down in rpm, below 500. confused..............
did u reset ur windows? hold up the buttons for like 5 secs.
if you disconnected the battery you have to let the computer reset it self, just play with them for a bit and they will start working again.
^^^in the manual it tells you how to reset everything after disconnecting the battery.
k i fixed it...thanks guys
god, i hate these retarded posts.
btw, don't forget to do your sunroof. |
Wow, I didnt disconnect my battery when i did my fogs or hid's and they worked fine, all of it was plug and play tho, I didnt really see the need to.
how easy were these HID's to install? I really wanna get some in 4300k but I need something that is as simple as plug and play. So if u can tell me how easy it would help me out a lot.
Well it would have been ALOT easier but I kept running into problems, like the pins on the harness were on backwards so I had to mess with those, then I had a pain in the a$$ time mounting the ballasts... overall they look really good, I just have to fix the angle on them because one shows brighter than the other so I just need the adjust the bulbs and angle them evenly...
btw, don't forget to do your sunroof. But yea, easy fix. Now you know. |
