OFFICIAL DIY/HOW TO: push button w/ diagram
Old Jun 16, 2008 | 12:52 AM
  #61
mattieg's Avatar
how would this work with a remote starter, also if you press the button just once will it turn on the accessories without turning on the car?
Old Jun 16, 2008 | 01:06 AM
  #62
faux_ghost's Avatar
nice DIY
Old Jun 16, 2008 | 08:16 PM
  #63
07SiC-tC's Avatar
i honestly don't know how it would work with a remote starter as i don't have one.
and i don't quite understand the second question
Old Jun 19, 2008 | 02:06 AM
  #64
mattieg's Avatar
On cars that have a push button start, you can press the button quickly and let go, and it will turn on the radio and other accessories without starting the engine. If you press and hold the button it will then start the engine. I was wondering if it was similar to that.
Old Jul 7, 2008 | 10:08 PM
  #65
STNC's Avatar
Ok, i've ran into a bit of a problem, im using the ignited button, and for the 85 pin that you connect together, where do you put them? do you make two sets? Its confused me
Old Aug 15, 2008 | 04:26 AM
  #66
teejoker12's Avatar
What is with all the relays? My friend and I just put a button in his civic. We spliced into the necessary wires and put it straight to the exact same button in the pics and it works like a charm. If needed, the key still works and it is still required to turn on the car.... I guess my question is, why do you need relays?
Old Dec 8, 2008 | 03:38 AM
  #67
Hix's Avatar
Hix
Is there any way to make it so turning the key will not start the car? Like could I cut the ignition down low and make a switch wired to the buttong so I need the key in the ignition, the switch hit and the button pressed to start the car. Kind of a f you try and hotwire it now button... I'm tired of getting my car stolen
Old Dec 8, 2008 | 03:43 AM
  #68
mattieg's Avatar
there is a chip in the key so they would need to key in order for the car to even run. How is your car getting stolen? The only way would be to put it on a flatbed.
Old Dec 9, 2008 | 02:59 AM
  #69
Hix's Avatar
Hix
Dunno but it has happened twice now. Recovered both times like a few hours later
Old Dec 9, 2008 | 05:52 AM
  #70
mattieg's Avatar
wow, if i were you i would get an alarm with a tilt sensor. This way if you car is jacked up the alarm would go off. And if you have a two way alarm, your remote would notify you of any disturbance of your vehicle.
Old Jan 14, 2010 | 04:32 PM
  #71
Streeter's Avatar
Hey, can you fix your images?
Old Jul 14, 2023 | 06:48 AM
  #72
Rohith000's Avatar
Hi, This is rohith. I have a 2010 Scion tc and I am looking forward to install push to start system in the car but, I am not sure what equipment need and how to install it.so, could you please help with the equipment so that I can order them.
mikejsmith1985
Scion xD ICE & Interior
Jul 22, 2012 05:41 AM
tdp124
Scion tC 1G ICE & Interior
May 24, 2010 08:27 PM
davidward
11
Dec 4, 2008 06:45 AM
