stock tweeter location
Where exactly is the stock tweeter location? How much trouble is it to throw in a set of components in the front if im going to just do a speaker swap and not run it off an amp?
Tweeter is behind... well the tweeter grill.. You need to pry off the panel where the large handle is (with the silver circle trim) and there you will find 2 scews. Loosen those. Then if you look closely you will see a panel where your door handle is... use a flathead with tape and pop that open and loosen the screw... then just pry the door panel off and disconnect the wire harness.....
ah, i assume the tweeter grill is by the door locks. Just wasnt sure if that was it.
^ yup. i would go with components! run the wires from the amp. no need to splice wires!
